Results 1 to 23 of 23
Thread: MYCOM approved oil ?
24-05-2008, 03:55 PM #1
Re: MYCOM approved oil ?
forgot to add in earlier post that Mycom will recommend change of shaft seal o/ring material compound as well,if using sythetic oil, your Mycom supplier should know that and advised you already. Stops leaking during operation due to oil / ammonia/ heat vacuum thing, Alignment on coupling is highly critical, recommend laser alignment, maximum total at mis-alignment less than 0.003, any measurment, radial . height , face to face, any which way. Mycom supply that sevice internationally.
hope this all helps.
magoo
Mycom 250VLD
By nh3wizard in forum NH3Replies: 12Last Post: 14-08-2008, 06:37 PM -
Mycom 160lud
By DSK in forum Industrial CompressorsReplies: 4Last Post: 15-12-2007, 06:47 PM -
Different between compressor MYCOM single stage and compressor booster
By thien nhat in forum CommercialReplies: 7Last Post: 13-12-2007, 06:31 PM -
Mycom N8wb
By faryuki in forum Industrial CompressorsReplies: 4Last Post: 13-12-2007, 06:21 PM -
Mycom screw documentation
By Josip in forum Industrial CompressorsReplies: 3Last Post: 13-12-2007, 06:13 PM
