Thread: "high flow" valves
30-05-2003, 12:56 AM #1
"high flow" valves
I just installed a Carrier 48TJE roof top unit.It has what they call high flow valves,one on the suction line,one on the discharge line.I've never seen these. It looks like a large access fitting.No threads...just a black plastic cap.I phoned Carrier and they were useless.In the literature,they call it a high flow valve that is not field serviceable.Anyone heard of these?
30-05-2003, 01:57 AM #2
Offhand, can't think of any reason why one would need a regulating valve in both the suction and discharge lines of a rooftop unit.
Perhaps they are simply full port ball valves? Perhaps they are being used in lieu of compressor service valves?Prof Sporlan
01-06-2003, 11:44 PM #3
Were the caps removable? Was there anything under them if so?
What next?
28-06-2003, 05:33 AM #4
Sounds like pressure relief valves. I've installed a lot of 48TJE's and can't imagine what acman is referring to. Can you post a picture?
Essayons
Stainless steel valves
By Tycho in forum NH3Replies: 5Last Post: 05-11-2008, 02:16 PM -
Hinari and how far to open valves
By stryker in forum Air ConditioningReplies: 6Last Post: 14-04-2008, 01:47 AM -
Suction Stop Valves
By frank in forum Air ConditioningReplies: 10Last Post: 02-08-2006, 11:04 PM -
Glycol water valves
By eng_ab in forum IndustrialReplies: 2Last Post: 03-06-2005, 09:15 PM -
Positon of tx valves
By Les Stuart in forum Trouble ShootingReplies: 5Last Post: 16-11-2003, 04:43 PM
