Thread: Electrolux freezer
12-02-2008, 11:25 PM #1
Electrolux freezer
Hello guys, anybody know what the parameter password is on an eliwell ID974 control which is fitted to an electrolux freezer?. I have spoken to hawco they said the default was "47" unless it has been changed by a cabinet manufacturer.
Andy
12-02-2008, 11:58 PM #2
Re: Electrolux freezer
Andy.
open the attached pdf and all may be revealed.
GrizzlyLast edited by Grizzly; 25-04-2008 at 01:44 PM.
13-02-2008, 12:23 AM #3
It won't let me get that far, it just comes up with PA1
Andy
13-02-2008, 12:38 AM #4
Andy.
Sorry I may have misled you, and you may be correct that you are locked out. Did you hit set after PA1? if you are still locked out. Try emailing eliwell on this website!
http://www.invensyscontrolseurope.co...lBulletins.htm
Also if you type in ID974 in the search box on the website.
Open the tech data and scroll down to bottom of details. You can open and download a specific pdf.
Which is 400+KB. So I can't upload it for you!
Sorry.
13-02-2008, 08:47 AM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Try with 0. If after pressing set you are not able to scroll threw the programing menu then password is enabled by cabinet manufacturer. Then try simple combinations as 11,22,33 etc..
If that don't produce access to parameters, you either need to call cabinet manufacturer for password, or if you have Eliwell software, you could threw him enter new set of parameters and reset pasword to 0 or any other value.Last edited by nike123; 13-02-2008 at 08:55 AM.
13-02-2008, 11:31 PM #6
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 01:26 PM -
Need help quick with walk-in freezer issues!
By hysiderafter in forum CommercialReplies: 5Last Post: 12-12-2007, 12:57 AM -
Trolley freezer & blast freezer
By smpsmp45 in forum NH3Replies: 0Last Post: 25-08-2007, 07:29 AM -
Project needs a freezer box.
By NC-Joey in forum FundamentalsReplies: 14Last Post: 16-08-2007, 01:27 PM -
Freezer efficiency questions
By M_Q in forum FundamentalsReplies: 8Last Post: 20-03-2007, 04:38 PM
