Thread: Liquid Pumps
    Mar 2004
    624
    21
    Liquid Pumps
    Visted a site today where they have fitted a invertor on the condenser fans ,lowered the head pressure and fitted a liquid pump.Just looking for views and information on liquid pumps.Are they good ??
    Regards Bernard
    Aug 2005
    5,302
    Re: Liquid Pumps
    Hi Bernard,
    Any refrigerant pump should be acceptable as long as the pump application parameters are met and the pump is designed for refrigerant service. The system you are describing essentially sounds like a HySave system used in years past for supermarkets and other commercial applications.
    Instead of running the system with higher discharge pressures to feed liquid refrigerant to the TXV's, the refrigerant pump simply provides the pressure to push the liquid to the TXV's. Rather straightforward, but...
    Refrigerant pumps are notorious for cavitating if the inlet pressure is insufficient.
    Jan 2008
    Kent UK
    49
    514
    Re: Liquid Pumps
    Hi Bernard.the pumps are being used to get head pressures from 200psi to 100psi at night to try and cut down costs.they seem to be working ok as long as the receivers are about 3/4`s full.have`nt had too many problems yet onlystupid alarms when all fans cut out.
    Jan 2008
    Kent UK
    49
    514
    Re: Liquid Pumps
    hysave website is very informative.RE wont let me give url.
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: Liquid Pumps
    Hi, chunky munkey
    Quote Originally Posted by chunky munkey View Post
    You crossed 15 posts limit now and you can post url try
    Best regards, Josip
    Jan 2008
    Kent UK
    49
    514
    Re: Liquid Pumps
    Thanks Josip now thats 16
  1. Replies: 13
    Last Post: 29-03-2008, 05:12 PM
  2. NH3 Liquid pumps
    By Gaz r in forum Fundamentals
    Last Post: 20-11-2007, 01:54 AM
  3. Ammonia Liquid Pumps
    By nh3wizard in forum NH3
    Last Post: 05-09-2006, 07:48 PM
  4. Parker levels in ammonia systems
    By Friobernal in forum Industrial
    Last Post: 04-08-2005, 03:46 PM
