Thread: need some help
    Jan 2008
    qatar
    61
    need some help
    hai everybody this is moorthy from qatar i need a help from you all, can i change refrigerant is r22 to 410
    TRY TO LEARN MORE ABOUT A/C SYSTEM
    Aug 2007
    Adelaide Australia
    70
    562
    Re: need some help
    Hi Moorthy No you can't replace R22 with R410. R410 is a high pressure refrigerant and you will find the pipework used on R22 will not withstand the pressure. Also all fittings for R410 are heavier and rated at a higher pressure. Regards Paul
    Feb 2008
    Las Vegas, NV
    67
    330
    Re: need some help
    Quote Originally Posted by rkmoorthy View Post
    moorthy
    Absolutely not! The compressor, components, controls etc... are not designed for the higher pressure, stay with R-22 or install a new R410 system.
    Jan 2008
    qatar
    61
    Re: need some help
    thanks for your reply mr paulz and powell. i have a split type a/c in my project, that is zenithair brand. this unit is using in R410A, in my location not available 410a,thats why i ask you to can i replace refrigerant 410a to r22.
    Split Croatia
    57
    6,151
    36
    Re: need some help
    Before, it was
    Now, it is
    Could you, please, decide what is going to be.
