Results 1 to 10 of 10
Thread: Whirlpool
09-02-2008, 12:30 AM #1
Whirlpool
I have a problem with american frigde freezer, compressor not getting power from PCB but condener fan motor running ( compressor and fan powered separately from PCB ).
I suspect problem with PCB, could it be anything else?
09-02-2008, 08:56 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Whirlpool
Bad connection (loose connector of compressor leads).
09-02-2008, 02:37 PM #3
Re: Whirlpool
all connections OK
does anyone know if there is any fault codes that can be displayed on front panel.
09-02-2008, 03:31 PM #4
Re: Whirlpool
have you got power to comp? check resistance on comp windings
09-02-2008, 10:12 PM #5
Re: Whirlpool
Hi DS,
Not familiar with this unit, but from what you mention in your original post I would guess you do have a problem on the pcb....assuming you have measured the power with a voltmeter at both the compressor and the pcb to eliminate broken wiring.
Does the pcb have Relays on it to switch the power through to the fans and compressor? These will probably have translucent plastic covers on them such that you might be able to see the contacts.
One trick is to gently tap them with your screwdriver handle...looking out for arcing from poor contacts.
The compressor should be powered when the condenser fan is powered.
Hope this gives you some ideas.
10-02-2008, 08:14 AM #6
Re: Whirlpool
Yeah bad relay on the PCB seems the most likely. Could you identify the comp relay? maybe check the coil on it?
I had a similar problem on a different brand fridge, and by getting the pcb out and tapping the relay, the comprsesor would start occasionally, so the PCB was replaced.
10-02-2008, 04:27 PM #7
Re: Whirlpool
will try new PCB and see what happens.
Thanks DS refrigeration
10-02-2008, 10:05 PM #8
Re: Whirlpool
My neighbour recently had this problem with his whirlpool fridge freezer. When there was demand one of the relays (the comp one) would sometimes not make contact properly. You could hear it buzzing and if you tapped it with a screw driver it would indeed work. After some de-soldering and testing as suggested by some posts on the UK Whitegoods site we found two of the capacitors for the relays with poor values. We changed all 4 (5 euros) and the fridge is now running fine.
There were so many cases of this fault on the above mentioned site that you might be forgiven for thinking it to be a built in design fault!
10-02-2008, 10:09 PM #9
Re: Whirlpool
Relay will cost $, pcb will cost $$$$$
10-02-2008, 10:54 PM #10
New Whirlpool Sideby Side 20RI D3
By StevenHarper in forum DomesticReplies: 6Last Post: 20-12-2007, 01:02 AM -
By skyguy in forum DomesticReplies: 3Last Post: 13-06-2007, 10:40 PM -
Help Needed Whirlpool
By cdsc in forum DomesticReplies: 10Last Post: 06-12-2006, 11:23 PM -
Ice Box on my Whirlpool Fridge/Freezer not working
By Chouman in forum Trouble ShootingReplies: 5Last Post: 18-09-2006, 01:23 AM
