Thread: Retrofit Temp Alarms
08-02-2008, 07:44 PM #1
Hi guys,
Great reading some posts on here...its pretty obvious you lot have a passion for all things cold.If you wouldn't mind what is everyones thoughts /advice on fitting a temp alarm onto an existing coldstorage unit.It would need to be able to send sms on alarm.
cheers
Wilt
11-02-2008, 12:22 PM #2
Re: Retrofit Temp Alarms
go for it, we have some really old rooms and sites that are alarmed, its good to know when temp is exceeded, just make sure you get the alarm settings correct
...and she said "give it to me you big fridgie"
11-02-2008, 12:41 PM #3
I'm with 750.
There is no reason why you could not change the alarm to any type of system you want.
taz.
11-02-2008, 09:13 PM #4
Cheers for the reply lads,
Any recommendations for a company who can supply a temp alarm ?
Also out of interest the walk in freezer has two seperate freezing units.I've noticed that by turning one off the inside temp only maybe drops by 1 to 2 'c and so I've started to cycle between the two.Do you guys forsee any probs....I don't think running singular puts any extra load on the motors but hopefully it will save on elecy
cheers
Carrier 23xl chiller-Low discharge superheat alarms
By Bradysmill in forum Trouble ShootingReplies: 7Last Post: 25-04-2010, 07:43 PM -
MP66 & Compressor Overheating
By Intermez in forum Technical DiscussionsReplies: 111Last Post: 13-04-2010, 08:58 PM -
display case temp alarms
By shark26 in forum Supermarket RefrigerationReplies: 9Last Post: 17-01-2006, 10:07 AM
