    turnerma's Avatar
    turnerma Guest
    Bosch - fridge warm freezer cold
    MOdel: KGN33V00GB (UK)
    Freezer works fine but no cold air is entering fridge. Unplugged drain pipe at back and let out water.
    No apparent blockages.
    Any help much appreciated.
    Thanks!
    Martin
    Aug 2007
    racine, wi
    68
    135
    Re: Bosch - fridge warm freezer cold
    if there was water in there,, chances are there is ice too. it can take a while to defrost the ice from in between the two.
    turnerma's Avatar
    turnerma Guest
    thanks -- much appreciated. will try that
    lebanon
    130
    hi
    u have to check if there is a frosty evaporator if so uhave to check thermistor heater timer themal fuse if every thing is ok u have an air return restricted by ice
    emyrj2005's Avatar
    emyrj2005 Guest
    hi,had this on a zanussi last month,try defrosting the grid at the top of the freezer compartment with a hair drier,the ice tends to build up at the back and blocks the air-flow up to the fridge compartment.
    biker t's Avatar
    biker t Guest
    definately having an issue with the auto defrost components. First check to see if evap. fan is in good order. check to see if heating element is in good order, check if thermal fuse is not open circuit, replace clixon regardless.before switching on ensure ice is removed from evaporator.additionly, make sure there is power getting to the evap.fan.
  1. fridge warm freezer cold?
    By babsnsarah in forum Domestic
    Last Post: 30-04-2011, 04:24 PM
  2. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  3. Bosch Fridge Freezer Error Code ??
    By madfriday in forum Domestic
    Last Post: 29-04-2010, 09:01 PM
  4. Zanussi - fridge is warm but freezer is cold.
    By Bob Ball in forum Trouble Shooting
    Last Post: 11-02-2007, 04:59 PM
  5. Freezer not cold enough, Fridge too cold
    By barrance in forum Commercial
    Last Post: 06-12-2001, 06:11 PM
