Thread: Insulation
08-02-2008, 01:41 PM #1
Insulation
Can any body give me the
1. comparision chart of the recomended insulation at different temperature.
2. Suitable thickness chart for EPS and PUF.
regards,
08-02-2008, 07:22 PM #2
Re: Insulation
Hi!
You may find the information (including selection program) on
http://www.armaflex.com/www/armacell...e?OpenDocumentLast edited by Brian_UK; 09-02-2008 at 12:49 AM. Reason: Allowed url.
09-02-2008, 05:44 AM #3
Re: Insulation
R u talking about Cold stores? You have to follow Ashrae reco wherein recommended R values are given
11-02-2008, 06:57 AM #4
Re: Insulation
I want to know about the thickness required for cold rooms?
11-02-2008, 11:52 AM #5
Re: Insulation
Try asking the manufacturers. They would be having it.
11-02-2008, 01:01 PM #6
Re: Insulation
In India, use 125mm Thk PUF / 200 EPS for -25
use 80mm thk puf/ 100mm thk EPS for Chill rooms
& 60mm thk PUF / 80mm EPS for Processing halls.
Again based on the heights, only for structural strength you may have to go in for thicker panels!!!
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
Insulation Testers
By Teknicool in forum Tools and CalculatorsReplies: 3Last Post: 23-12-2007, 01:41 PM -
Emmisivity as insulation thickness determinant ?
By sharshal in forum Technical SpeculationsReplies: 4Last Post: 23-10-2006, 02:26 AM -
insulation panels
By tonto33 in forum CommercialReplies: 0Last Post: 16-10-2006, 02:16 PM -
Suspended Floor Insulation
By Colin Kaminski in forum CommercialReplies: 2Last Post: 08-02-2006, 06:10 PM
