Thread: motor
    sendy's Avatar
    sendy Guest
    motor burn clean-up procedures
    I have problem with, Motor Burn Clean-up Procedures.What can i do?
    Split Croatia
    57
    6,151
    36
    Re: motor
    495
    21
    Re: motor
    Hello Sendy if its a big system then put in a suction drier strainer in with removable drier cores.First put burn out cores run the system until the oil goes round then, do an acid test on oil ,if ok run it for a while longer , then change the cores to high capacity cores and do an oil change ,keep doing it until the oil is free of acid and looks clean ,and then put in normal drier cores.If you have a low temp system remove the drier cores because you will loose duty due to pressure drop across the strainer . good luck
  1. Compressor loading, cooling, and range of operation.
  2. dual voltage fan motor
    By bill1983 in forum Electrical
    Last Post: 09-05-2007, 10:36 PM
  3. help with testing 3 phase comp
    By mat in forum Fundamentals
    Last Post: 19-01-2007, 09:03 AM
  4. Fan motor over heating & Shuting down.
    By Rookie in forum Domestic
    Last Post: 30-06-2005, 11:21 PM
  5. Fan Motor
    By Coolie in forum Technical Speculations
    Last Post: 16-02-2005, 08:03 PM
