    Aron's Avatar
    Aron Guest
    Help on Assignment
    Xxxxxxxxxxxxxxxxxxxx
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: Help on Assignment
    Hi, Aron
    Quote Originally Posted by Aron View Post
    Hello everybody!
    I would really appreciate if someone can help me with assignment that I need to work on.
    Assignment:
    Equipment for refrigeration of 5000 lit/hour of beverages from temperature 20°C to 8°C, is installed in factory for production of non alcoholic beverages. Refrigeration is performed indirectly, using ethyl-alcohol.
    Refrigerant used is R-22 and temperature of water used for cooling is tw1=10°C
    I need to:
    1. draw equipment schema and refrigeration cycle
    2. determine temperature of evaporation in order for equipment to cover refrigeration load.
    3. calculate compressor force according to results determined under topic 2.
    Hope that someone can help me or can give me some advices where to look for some similar example.
    R22
    Best regards, Josip
    Split Croatia
    57
    6,151
    36
    He is student of some type!
    11,024
    He says "engineer"
    1. You should be able to draw the schema and refrigerant cycle.
    If not then you need to do a lot of reading before you can continue.
    2. Determine load.
    See above comment.
    3. Compressor sizing.
    See above.
    Has your tutor not given you any guidance on the subject ?
    Aron's Avatar
    Aron Guest
    thank you guys.
    You really helped me. I got it.
