Results 1 to 15 of 15
Thread: Oiling flares
05-02-2008, 05:43 PM #1
Oiling flares
Good afternoon everyone
I would like to buy a small pots of mineral / esther oil to keep for installation work when making flares, but I can't find anywhere selling less than 4 litres. If anyone knows of a supplier offering this I would be most grateful .
05-02-2008, 06:17 PM #2
Re: Oiling flares
Rather than buying a larger quantity than you need, get yourself down to the local chemist and ask them for a sample bottle. They will usually give this FoC, then next time you change your vac pump oil, (which you should do on a regular basis) you can fill your sample bottle with vac pump oil, which is more than adequate for flarenuts.
Happy flaring. Andy C.
05-02-2008, 07:52 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,175
- Blog Entries
- 6
- Rep Power
- 36
Re: Oiling flares
I using eye drops bottle filled with vacuum pump oil!
05-02-2008, 11:21 PM #4
Re: Oiling flares
You can get 1L ester oil cans (emkarate sw32) from climate center or rpw and probably many more. I use ester oil on all my flare, including systems running on mineral oil.
06-02-2008, 12:34 AM #5
Re: Oiling flares
Greenmill supplies of colchester do mail order and sell a small (130ml) bottle of universal flare nut oil. their phone no is 0800 2795 999 and no i dont work for them.
Hope this is of help.
06-02-2008, 01:34 AM #6
Re: Oiling flares
Just buy an oil can from a tool shop and fill it up from a big bottle whenever it gets empty..simple,cheap, effective
06-02-2008, 09:49 PM #7
Re: Oiling flares
Thanks everyone, during training I was told to use a small pot of 'virgin' oil and then dispose of it due to the hydroscopic nature of esther oils . This may be a bit OTT for some I guess, Daikin used to supply sealed little pots with their splits...
06-02-2008, 10:20 PM #8
Re: Oiling flares
you are only going to use it to put on flare joints and not in the system so as previously suggested i use vac pump oil in a squirty can that i got from a car factors.
Either that or use leaklock on every thread
By the way NRS have stopped selling leaklock, anyone know why
Fatboy
06-02-2008, 10:29 PM #9
Re: Oiling flares
You could also tip a few drops out of a new comp.
Any oil will do, even engine oil or cooking oil. The oil doesn't enter the system as you will only be putting it on the back of the flare not the mating surface.
and go get a cuppa
07-02-2008, 04:15 PM #10
Re: Oiling flares
I agree.
i just use left over diesel engine oil from when i service my car. Even if a tiny bit did enter the system it would have absolutely no effect.
09-04-2008, 12:28 AM #11
Re: Oiling flares
I was taught to OIL BOTH the BACK and the FACE of the flare. What has changed? DAIKIN still recommend that the face and back of the flare is oiled, well at least their installation manuals do.
Perhaps we are all getting a little hung up on contamination by the wrong oil or moisture in the ester oils? I still oil them this way and I will continue until I see a proven reason as to why I shouldn't. By the way I have not had a leak on a flare on an install carried out by us in six years of trading! I must be doing something right! Mind you I do use a good torque wrench!Last edited by Refrigerologist; 09-04-2008 at 12:32 AM.
09-04-2008, 05:34 PM #12
Re: Oiling flares
I just use what ever old oil I have at hand, mostly mineral, dip a bit on a coth then wipe down the flare, never an issue.
10-04-2008, 03:12 PM #13
Re: Oiling flares
10-04-2008, 08:50 PM #14
Re: Oiling flares
A little oil on the yoke helps with formation
10-04-2008, 09:23 PM #15
Re: Oiling flares
Indeed, you have a point, forgot this one.
Flares .....?
By Argus in forum History of RefrigerationReplies: 40Last Post: 10-11-2008, 11:32 PM
