03-02-2008, 08:11 PM #1
cervinho blast freezer/chiller problems
Hi to all just wondering if anyone has had much experience on ital cervinho blast freezer/chiller.
Can't find any information on fault codes anywhere.
The cabinet I'm working on was tested as follows-
-bowl of hot water in (65 degreescelcius)
-food probe into bowl
-initiated blast chill
all worked ok for about 20 minutes temp went down to 10 degrees then all of a sudden the cabinet shut down and was showing minus 24 degrees. Checked inside with my probe and it was at 10 degrees.
I have since changed the food probe but the same thing keeps happenig.
Help would be much appreciated thank you.Last edited by 1mikeefc1; 04-02-2008 at 07:31 PM.
03-02-2008, 08:40 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: cervinho blast freezer/chiller problems
What controller they are use?
04-02-2008, 07:31 PM #3
the controller has no model or any markings on it at all and is unlike any other i have seen.
it also doesnt look like it can be replaced.
04-02-2008, 07:51 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Based on what you saying, it is possible that you have some bad electrical contact in wiring of probe , or controller is faulty.
05-02-2008, 11:43 PM #5
Thanks for the advice. As I have changed the probe and the controller won't come out I will check all connections and if still persists then the catering supplier can change the cabinet.
Carrier 30XA Liquid chiller Problems
By Ed Burris in forum CommercialReplies: 7Last Post: 13-08-2010, 08:12 PM -
samsung rs21dcns problems
By slovenian ian in forum Trouble ShootingReplies: 2Last Post: 03-11-2007, 03:19 AM -
Suction pressure problems on TS units at low ambient temps
By nova in forum TransportReplies: 10Last Post: 18-03-2006, 07:35 PM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM -
oil pressure problems on air dryer
By edge in forum Trouble ShootingReplies: 1Last Post: 16-07-2002, 02:10 PM
