Thread: Need frigees help on Cold room..
03-02-2008, 05:01 PM #1
Hi all
i am predominantly air con and have been asked by a friend for a price on a cold room installation.
She already has the room its old but Usable, (my opinion)
It has good seals on door and seem's Ready.
What it lacks is its guts....scuze the expression,
What i need to know is where to buy what to buy...
Requirements=
going to house cakes ready made sandwiches etc..
Coldroom dimensions=
w=1.2 or 6ft
L=1.8 or 6ft
H=1.9
hopfully not to vague and would appreciate any advice.
Regards Lee
03-02-2008, 06:39 PM #2
Re: Need frigees help on Cold room..
Have you ever been to NRS (control centre), Dean & Wood, HRP or NRW and the like.
Phone them up with the measurements and they will give you the size of the evap and condensing unit.
Then just compair the prices. If your doing it for a friend then be sure you go for the right sized unit don't scrimp on th horse power
cheers taz.
03-02-2008, 11:42 PM #3
Cheap solutions for friend : take an external unit AC , 9000 Btu/h , disconect 4way valve and capillary tube , use CoolPack for evaporator size , put "heat pump capillary " inside , one Dixell or similar controller and you have the system.
I make-it and it work.
Gramcor
04-02-2008, 12:06 AM #4
04-02-2008, 12:06 AM #5
Hi Raison,
As you are going to store food in coldroom, I must ask what is the state of the 'old' room and what was it previously used for. You really need foodsafe surfaces for food that is for consumption without further cooking. Some old rooms only had galvanised surfaces designed for fruit and veg or meat. If previous use was meat then need I say more as to state of floor etc and what bugs might be lurking.
Possibly check with local council health inspector to get their opinion....dont want to waste money if not suitable.
SRW do coldroom packs of evap, condensing unit, pipe and controls etc. They will also size up equipment. Give thought for high ambient temperatures if in kitchen and summertime. Aim for 43 deg ambient rating.
Also consider new packaged coldroom - easy to assemble and complete with refigeration unit...just plug in.
Good luck.
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
Cold room dimensioning - ratio volume air flow
By MrReds in forum Technical DiscussionsReplies: 11Last Post: 17-11-2007, 10:51 PM -
cold room
By CHILLED4 in forum Trouble ShootingReplies: 5Last Post: 16-11-2007, 11:44 PM -
LG Capacitor - Room not cold
By kelamel in forum Trouble ShootingReplies: 8Last Post: 21-10-2006, 10:50 AM -
Installation of cold room
By Josip in forum Legal-Business-MarketingReplies: 12Last Post: 12-03-2006, 09:20 PM
