Results 1 to 21 of 21
02-02-2008, 09:23 PM #1
request manual of container chiller
hai anybody send me carrier container chiller maintenance and service manual
TRY TO LEARN MORE ABOUT A/C SYSTEM
02-02-2008, 10:54 PM #2
Re: request manual of container chiller
I have few service manuals for Carrier , Transicold , Container Refrigeration Unit. If is useful , send me an email adress .
Gramcor
03-02-2008, 11:21 AM #3
03-02-2008, 11:22 AM #4
thanks for your reply
03-02-2008, 08:34 PM #5
thank you mr gramcor please send to me carrier container chiller maintenance service manual
03-02-2008, 08:46 PM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
rkmoorthy,
could you be little less annoying and impatient?
03-02-2008, 11:23 PM #7
Hello
Is impossible to send url . If you want , type so :
worldwideweb, dot,container, dot , carrier , dot , com, slesh , details, slesh, "0,2806,CLI1_DIV9_ETI742,00 ", dot , html.
Gramcor
04-02-2008, 12:23 AM #8
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
04-02-2008, 12:40 AM #9
Link provided by Gramcor is....
http://www.container.carrier.com/det...ETI742,00.htmlBrian - Newton Abbot, Devon, UK
04-02-2008, 01:07 AM #10
Thanks for help.
Gramcor
22-03-2008, 10:17 AM #11
hi guys this moorthy from qatar. in qatar not available r410 i have 50 zenith air unit. so i need details of alternate refrigerant for 410
13-08-2008, 11:19 AM #12
hi every body
hi this is moorthy from qatar. can you any body help me to solve the problem of PETRA 15 ton packkage type ac unit.
problem
1. compressor diffected.
changed compressor. before change compressor i cleand the refrigerant pipe line use with r11 and nitrogen. chnged filter dryer,and cleaned exp valve vaccuam 3 hours,charged r407c. but after the expansion valve and capillary tube too much ice formed.
hp 275psig
lp 35 psig
amp 25A (this is permisable leve
out temp 45c
condencer cleaned
can you some body give details how to solve this prb.
13-08-2008, 06:44 PM #13
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: hi every body
Before anything check your oil acidity level. Then change expansion valve, if need, change oil, install over sized suction filter-drier and new liquid line burn-out filter-dryer.Then after that, make pressure test and good evacuation (check that your achieved vacuum with electronic vacuum meter is at least 500 microns and holding) recharge with new virgin refrigerant by weight.
30-09-2008, 07:04 PM #14
hi there im a new reefer technician sir.can you pls help me pls. send me as many reefer manuals as you can i need to have a little backround on this job, because life is so hard here in PH... pls help me sir
thank you so much may GOD bless you...
elmerfrench@yahoo.com
30-09-2008, 07:06 PM #15
01-10-2008, 09:01 AM #16
Pls may you send me operations manuals of Container Refrigeration.
If you know some one who is looking for job for container refrigeration( carrier and thermoking), please let me know or send cv to my email address mnm_kuwait@homail.com. Urgengly required
01-10-2008, 09:28 AM #17
Any one can tell me about the online Referigeration, Air conditioning and Reefer Training Courses.
Best Regards.
Pls information can be sent to me on my email address mnm_kuwait@hotmail.com
19-11-2008, 01:46 PM #18
05-12-2008, 11:34 PM #19
Hi Nadeem,
If you want learn how is repair to reefer container units i may help you..
You can send e-mail to me.
serkan.humasalar@ardep.com.tr
best regards.
serkan h.
08-07-2010, 02:33 AM #20
Hi Guys,
I too need the reefer manuals for the major brands. Please email me at kpasirio@gmail.com
06-09-2010, 03:09 PM #21
can i have copy of the manual too. tnx
hi! everyone, im new here, need help for refrigerated container, i want to learn more about it, anything will do. thanks!Last edited by chillin out; 19-09-2010 at 08:00 PM.
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
Freeze Up Auto Or Manual In Chiller?
By abbasi in forum FundamentalsReplies: 9Last Post: 10-02-2006, 02:48 PM -
chiller manual
By zimbo in forum TrainingReplies: 2Last Post: 28-01-2006, 05:38 AM
