Results 51 to 57 of 57
Thread: Single screw compressor
16-03-2008, 05:55 PM #51
Re: Single screw compressor
Working for manufacturers will allow you to learn a lot in a short time. They see every little problem you can think of with refrigeraiton systems.
Why?
Because everyone always blames the equipment for not working properly and they have to work with the customer to provide a solution.
If you do this for the learning experience it is OK. If you do this for the money you will be disappointed.
24-02-2009, 07:49 PM #52
good day,Hello Sir, I am kamaludeen from saudi Arabia. We have Hallscrew HS2031 compressors with fridgewatch 2000 controller. We have problem with this controller. Could you please help me in solving the problem or please send me the resetting controller manual to my mail ID
25-02-2009, 12:45 AM #53
03-03-2009, 06:46 PM #54
Reality check here. The screws dont have much between them. seriously they are practically the same in every way. All it is with reliabilty is that the engineer who built the machine and the engineer who is looking after the machine. All manufacturers test their machines to destruction im sure. They know what they can do. Single screw is very reliable as long as the running conditions are correct. I have had one running a very long time 10yrs+ on -25 duty single stage and has never had a bearing change. Just the same as ive seen twin screws doing the same. Design and commissioning is important but not everything.
25-12-2009, 03:47 PM #55
Tri-Therm AC2120i/HA3R CHILLER IOM AND CONTROL DIAGRAM
HI every one i need tri-therm AC2120i/HA3R IOM an automation control diagrams if some one have please send it to my e-mail airaakram@yahoo.com because previous maintenance contractor has missplaced I came to know tri-therm company has closed so i unable to contact them early responce will be highly appreciated
thanks
akram
28-12-2009, 05:57 AM #56
LOL I guess nobody here went to the Frick sales meeting? Nice presentation on single screws vs twin screws.
28-01-2010, 03:40 PM #57
I purchased 4 Vilter VSS mono screws, had many problems with capacity control gear motors, liguid injection control and pump problems. Slide valves would rub on the screw and gate rotors would wear out quickly. Also had to rebuild each one as least once in a five year period. I now have 4 Frick RWF-II twin screws and have had to rebuild only one in ten years.
Experience with a specific screw compressor
By TXiceman in forum CommercialReplies: 17Last Post: 07-04-2009, 07:00 AM -
do u have any data on comparison of single screw and twin screw?
By vuputuri in forum Technical SpeculationsReplies: 5Last Post: 22-02-2008, 03:52 PM -
single stage screw compressor
By murugan in forum Trouble ShootingReplies: 0Last Post: 18-05-2006, 01:27 PM -
Screw compressor vibration
By jpumarada in forum Industrial CompressorsReplies: 14Last Post: 26-04-2006, 01:43 PM -
screw compressor failure
By aygul in forum Trouble ShootingReplies: 23Last Post: 09-12-2004, 09:09 AM
