Results 1 to 50 of 57
Thread: Single screw compressor
15-03-2008, 05:05 PM #1
Re: Single screw compressor
Originally Posted by sagittarius
And, what does this have to do with the manufacturer and why you might want to work for them?
One month you ask about markets and product quality and then the next month you ask about working for a manufacturer?????
Asking which compressor is better is like asking a man if a woman is pretty. Some say yes, others may not (but not in front of the woman)If all else fails, ask for help.
15-03-2008, 09:55 PM #2
The subject of variable Vi is very interesting. As i have said before, i have not any experience with large and/or industrial systems. On dual screw compressors with variable Vi, i clearly see the need for fully independent movement of the capasity slide and the varable Vi slide in order to maintain the best isentropic efficiency at all pressure and load ratios. I have however got the impression that variable Vi is not fully acomplished when the compressor is running in part load. Can someone explain if this is the case and why?
Experience with a specific screw compressor
By TXiceman in forum CommercialReplies: 17Last Post: 07-04-2009, 07:00 AM -
do u have any data on comparison of single screw and twin screw?
By vuputuri in forum Technical SpeculationsReplies: 5Last Post: 22-02-2008, 03:52 PM -
single stage screw compressor
By murugan in forum Trouble ShootingReplies: 0Last Post: 18-05-2006, 01:27 PM -
Screw compressor vibration
By jpumarada in forum Industrial CompressorsReplies: 14Last Post: 26-04-2006, 01:43 PM -
screw compressor failure
By aygul in forum Trouble ShootingReplies: 23Last Post: 09-12-2004, 09:09 AM
