Results 1 to 50 of 57
Thread: Single screw compressor
03-10-2007, 05:16 PM #1
Re: Single screw compressor
Dear friend:
I have seen many Vilter single screw compressor working very well during let say 10 years, they perform fine and there is not a lot of repair cost, in fact they just need little maintenance.
Also because of their continuous Vi they are more efficient.
15-12-2007, 06:39 PM #2
hola guys,
i notice some blinds leading the blinds here!
does any of you work for compressor manufacturer before?
it is of danger if rookie engineer applies what you have said.
single vs twn screw?
1] perfromance difference = yes;
2] cost difference = yes;
3] maintenance diffirence = yes.
twn screw use smaller e-motor compared to single @ similar cooling cap.
initial cost is low for single.
maintenance cost is low for single.
runnign cost is high for same cap.
any other thing you wish to know?
16-12-2007, 12:45 AM #3
16-12-2007, 12:53 AM #4
17-12-2007, 08:11 AM #5
17-12-2007, 04:02 PM #6
I work on both types of screw and can recommend models from both Camps.
In simple terms "You get what you pay for". Yes Hall Screws are High Maintenace. Compaired with some cheaper " sealed for life" twin screws.
But when you refer to a Halls maintenace manual.
It says something like " Every 24 years or 100,000 hrs (11.4 yrs of running) Renew the main bearings.
That's pretty impressive in my book.
More importantly when they do go wrong you can repair them. Because the Star wheel is sacraficial compared to comprable damage on a twin screw.
Likewise I have a site with 2 stahl (twin) screws ( On Ammonia) that in nearly 20 yrs have only needed Oil Filter changes and a shaft seal each.
Brilliant Machines no longer made ( to well engineered making them expensive to produce. I Believe?)
To often equipment is purchased purely on cost and not longevity nowadays.
There appears to be cheap twin screw models out there that are supplied on a disposable basis. When it breaks rip it out and put another one in. These cannot be compaired with the more expensive and reliable models from both camps.
Yes I did work for J&E Hall.
But I can appreciate good kit wherever it is made.
Sometimes good equipment fails because those looking after it are not up to the job!
18-12-2007, 01:53 AM #7
Experience with a specific screw compressor
By TXiceman in forum CommercialReplies: 17Last Post: 07-04-2009, 07:00 AM -
do u have any data on comparison of single screw and twin screw?
By vuputuri in forum Technical SpeculationsReplies: 5Last Post: 22-02-2008, 03:52 PM -
single stage screw compressor
By murugan in forum Trouble ShootingReplies: 0Last Post: 18-05-2006, 01:27 PM -
Screw compressor vibration
By jpumarada in forum Industrial CompressorsReplies: 14Last Post: 26-04-2006, 01:43 PM -
screw compressor failure
By aygul in forum Trouble ShootingReplies: 23Last Post: 09-12-2004, 09:09 AM
