Thread: ***** leak Monitering System
31-01-2008, 12:33 AM #1
Hello, Every One
I am looking for ***** leak monitoring alarm system, Could be one or multi sensor.Please let me know,which one is good one and have good Experience with it
*****: R-404A
Application: Walk in Box
City/State: Burbank/California, USA
Amrit Ghumman
03-02-2008, 05:02 PM #2
Re: ***** leak Monitering System
A number of manufactures have ***** sensing monitors. Some are refrigerant specific, some are general.
Gensis makes some as does Honeywell.
They provide multiple sensing points and alarm levels for engine room applications. Outdoors is a problem due to wind currents.
Mike do you remember the name of the monitors Frank Weirts had before it was bought by Honeywell?
ken
03-02-2008, 05:25 PM #3
I think it was Manning.
03-02-2008, 07:10 PM #4
try typing parasense into google(other search engines are available) for a multichannel leak detector. alternatively hussman via stonegate instruments used to do a single channel leak detector.
the parasense detectors have varying degrees of sensitivity and are very reliable.
most good wholesalers will stock a single channel detector.
06-02-2008, 02:24 PM #5
It was Manning....the old gray matter is getting a bit fuzzy...
K
07-02-2008, 03:04 AM #6
Bacharach has good refrigerant monitors and you must specify refrigerant being detected.HGM,RDM styles are what I use.They are also available with a 4-20 ma card for communicating to a energy management system.You can order with audible alarms and strobe lights.
09-02-2008, 10:27 PM #7
We use a parasense system and a TQ Environmental both are multigas multisensor systems. Both are pretty reliable so I guess the only split would be the price... I haven't got a clue on that I'm afraid.
Daikin fault codes
wats the best tool for ***** leak detection
By jess in forum Tools and CalculatorsReplies: 58Last Post: 28-11-2011, 05:31 AM -
compare ***** dx with overfeed system
By COLD WANG in forum CommercialReplies: 3Last Post: 12-12-2006, 05:07 PM
