Results 1 to 19 of 19
    Jun 2005
    Stoke on Trent
    588
    12.5 kw wall mount air con
    Hi guys,
    I have just sized up a job and the requirement is for a wall mount cooling only air conitioner (or heat pump) the room is an attic so there is no room for a cassette or underslung, I have space on the wall to install a suitable wall moun or ceiling wall convertible unit (for wall mount) but cant seem to find a wall mount bigger than 10 kw or a convertible bigger than 8 kw, LG used to do a big convertible but no listing of it now, I have checked LG, Sanyo, Fujitsu and Mitsi electric.
    Does anyone know of others?
    Apr 2006
    stafford
    42
    974
    Re: 12.5 kw wall mount air con
    Paul
    "KEEP IT COOL"
    Feb 2007
    2,473
    45
    Or a Tosh SMMS with 2 indoor units?
    Jun 2005
    Stoke on Trent
    588
    I will have to ring LG as Oceanair website does not show the large wall/ceiling models, thinking about a wall mount it may not be suitable as the flat wall is only 1m high, the rest is the inside pitch of the roof so the air discharge would be too low, definately a wall mounted unit with a top air discharge is required.
    Feb 2007
    2,473
    45
    IMI?
    (which the system wouldn' let me post as there is a minimum of five letters reply)
    Split Croatia
    57
    6,151
    36
    Why you are concentrated such amount of capacity on one place. Around that air conditioner is going to be very unpleasant (high air flow and to low/high temperature).
    Consider placing two or more smaller units.
    Jun 2005
    Stoke on Trent
    588
    The reason been is that it is an archive room with a server in it, in a loft space, un occupied.
    I installed a large LG wall/ceiling a few years ago and it was certainly a noisy beast!
    I shall ring the customer today as he has not allowed enough in the budget to do the work.
    Thanks guys.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Andy W View Post
    Thanks guys.
    I don't think that residential split system is solution for that job but, I may be wrong!
    Nov 2007
    Scotland
    43
    I've in the past used large Hitachi wall mounts for similar applications, but they don't seem to do them anymore.
    What about an LG P05AHNTO floor standing indoor, (upright type, 13.48kw) ?
    May 2006
    Hayling Island, UK
    143
    21
    Could a 'twin-split' work?
    Pair of 6kW hi-walls on a single outdoor??
    Suggest 2 x RAV-SM802KRT-E hi-walls onto an RAV-SM1402AT-E outdoor - Toshiba models.
    But use the hard wired controller - KRT come with infrared and the end user will probably loose it, also you can set up auto-restart with the wired one.
    Loops
    Jun 2005
    Stoke on Trent
    588
    We dont have a vertical wall any higher than 1 metre, imagine the shape of your attic and plasterboard lined, we dont have the height for anything tall apart from right in the middle of the room and a standard wall mount would not give us the air flow as they are bottom air discharge and we have a 1m vertical wall, highest point of ceiling is 2.4m.
    Jul 2007
    Andy,
    The only thing you can do is use a twin split system. I would suggest a Hitachi RAS 5.0H(V)RNE outdoor with two RPF 2.5FSNE low level floor standing indoors. They are only 630mm high, so should fit in okay.
    May 2006
    Sussex
    362
    What's in the Archive - just regular documents or valuable historic delicate books etc?
    Feb 2007
    2,473
    45
    What's on the floor below?
    Is there a ceiling void where you could put a ducted unit and then duct the air through the floor?
    Jun 2005
    Stoke on Trent
    588
    Quote Originally Posted by Makeit go Right View Post
    No just deceased patients details.
    Quote Originally Posted by The Viking View Post
    Occupied office space.
    Now that it is a good idea if they would consider removing tiles and grid etc to allow access, it is a new build and someone forget to air condition the attic area.
    Aug 2009
    Australia
    10
    I believe that Carrier have a Toshiba unit that may do the job.
    Nov 2006
    Cheshire, UK
    56
    360
    If U can 'get away' with a 10kW unit Mitsi Elec have just released a new 10kW Power Inverter unit which is the same width & height as their 7kW units only a little deeper.
    We fitted two recently and they perform very well indeed.
    He who dies with the most Toys, WINS!
    11,025
    If, he is still interested, please check the dates guys
  19. #19
    Feb 2005
    United Kingdom
    56
    bit late for this but no japanese ac manufacturer makes a wall mount larger than 10kw nominal
    IMI Hi Lo systems are the only ones that would suit the application assuming they are still available. They were available up to 54000 btu's
    Tosh dont do a 10kw wall.
    LG 10kw is a domestic unit
    Hitachi up t0 11.2kw may be worth considering
  1. IMI WM 60 Wall Mount R407c
    By rootsy in forum Electrical
    Last Post: 23-07-2007, 05:42 PM
  2. Fresh Air Wall splits
    By gwilliamson in forum Air Conditioning
    Last Post: 23-03-2007, 06:03 PM
  3. wall mount pumps
    By refaircon in forum Air Conditioning
    Last Post: 23-03-2007, 11:21 AM
  4. Daikin 5kW wall mounts.
    By Temprite in forum Air Conditioning
    Last Post: 20-10-2006, 12:17 PM
  5. R407 C wall mount LG 7 Kw
    By Abe in forum Air Conditioning
    Last Post: 12-07-2004, 10:35 PM
