Thread: Ice Bank System Supplier
12-11-2002, 01:41 PM #1
Hello ,
I am looking for a designer cum manufacturer of Ice Bank
system for producing chilled water at 1 deg c.
Thank you,
R.Sivakumar,
Chennai, India
31-10-2009, 11:10 AM #2
Re: Ice Bank System Supplier
We can designe & supply Contact
09850747403
31-10-2009, 11:13 AM #3
31-10-2009, 02:52 PM #4
It is a waste of energy to cool milk with cold water but if you insist, use a failing film water chiller.
One of the best ice banks manufacturers is Baltimore air coil, google them up.
31-10-2009, 08:42 PM #5
Or Packo, in my backyard http://www.packo.com/en/5841
01-11-2009, 01:21 AM #6
01-11-2009, 06:29 AM #7
Nope.....
DX milk tanks are the most efficient.
When you cool water and with the water you cool the milk, you loose energy.
You also need extra milk pump for the heat exchanger.
Its the fastest way to cool milk but not as efficient as DX.
01-11-2009, 10:08 AM #8
In NZ we pre-cool with bore water, ans then with a DX milk tank, I agree with chemi, DX has to be better when refrigeration is used, every step is a lose of efficency.
In NZ many companies are promoting thermal storage, as more efficient, It may be cheaper to run as you can use night rate power.
Cooling will be quicker with a secondary refrigerant, via a PHE.
A simple ice bank will have a lower captial cost compared to a large DX system.
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 11:09 PM -
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 10:47 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 04:42 PM
