    Oct 2006
    India
    56
    7
    Troubleshooting.
    Dear RE members,
    While conducting performance test of watercooled DX screw chiller in factory I have following observations.
    Charged less than spec.( R& D)
    Capacity is less by 3%
    Discharge/suction pr. as per design
    subcooling 5 deg C
    Suction superheat is @ 3 deg C.
    Discharge superheat 27 deg C.
    I need to know do I have to charge additional gas or not?
    Since suction superheat is low if I open TXV my capacity will be dropped.
    Pl. suggest solution.
    Thanks in advance.
    Zacatelco Tlaxcala
    54
    5
    Re: Troubleshooting.
    Hi refystem, if you check the discharge pressure you can determinate if your system have the correct referigerant chargecould you send me the suction pressure and the discharge pressure
    agitator's Avatar
    agitator Guest
    Quote Originally Posted by refsystem View Post
    Dear RE members,
    subcooling 5 deg C
    Thanks in advance.
    hello,
    if not enough gas yes u need to charge, but make sure that you must have enough load ( for heat transfer ) what kind of refrigerant you used, is the system have level gauge or refrigerant sight glass
    for screw compressor mostly the design base is 10~20degc suct superheat at full load
    Oct 2009
    merida mexico
    282
    How to make and model of machine is?
  1. troubleshooting books
    By marc5180 in forum Refrigeration Books
    Last Post: 04-04-2009, 06:08 PM
  2. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
  3. Copeland scroll troubleshooting
    By nike123 in forum Trouble Shooting
    Last Post: 26-02-2008, 05:37 PM
  4. Looking For A Good Troubleshooting Guide
    By nightranger121 in forum Trouble Shooting
    Last Post: 23-11-2007, 06:16 PM
  5. Troubleshooting my Fridge
    By IslandGirl in forum Domestic
    Last Post: 23-08-2006, 10:33 AM
