    Feb 2004
    Australia
    286
    15
    Trane Centrifugal Chiller
    Is it possible to change the oil filter on an old Trane Centravac chiller without removing the R123 charge. There are no isolation valves on the filter. THere is a service bulletin which provides details of an oil piping upgrade but there must be a way to chane the oil filter.
    a problem shared is a problem halved
    krak's Avatar
    krak Guest
    Re: Trane Centrifugal Chiller
    Hi could you give me the exact model and serial number.
    I want to look up over the technical documentation.
    Thank you.
    Aug 2001
    Gold Coast, Australia
    601
    22
    Probably not.
    Silly question, but have you asked your local tech. support?
    Seconding krak on the model & ser. no please.
    Aug 2003
    Netherlands
    43
    621
    15
    Me too, need the serial and model number to be sure!
    Jun 2006
    British West Indies
    545
    12
    The model and serial number means nothing. The tank head could have been changed/upgraded or the oil fitler could have been modified. JMHO
    Take the V out of HVAC and you are left with a HAC job
    Dec 2005
    Johor
    56
    151
    13
    Hi Iceman 007,
    Raise the pressure to just slightly above '0' psi and do not allow system to be in its vacuum stage. For safety precaution put on your gas mask. Immediately unscrew and replace the oil filter cannister. Check with you, are you refering to the LOCV,CVHE,CVHG? By the way good luck on your quest mate.
    Oct 2009
    merida mexico
    48
    282
    9
    If possible change filtro.incrementa the pressure of the machine to 0psig, and changing the filter subsequently reduces the pressure to empty and pon in operation in purging way manual to remove air
  1. Replies: 16
    Last Post: 20-02-2008, 11:15 AM
  2. R11 Centrifugal Chiller Oil Problem
    By iceman007 in forum Trouble Shooting
    Last Post: 17-02-2008, 02:14 AM
  3. Trane Chiller low temperature operation
    By Brads in forum Industrial
    Last Post: 20-01-2008, 07:18 AM
  4. Connecting Trane Water chiller to air handling unit
    By celtictech in forum Fundamentals
    Last Post: 08-03-2007, 06:14 PM
  5. trane chiller
    By ric in forum Air Conditioning
    Last Post: 14-09-2006, 08:03 PM
