    Nov 2006
    INDIA
    10
    Unhappy Oil circulation system in Reciprocating refrigeration system
    Dear sir,
    I WOULD LIKE TO KNOW THAT REFRIGEARTION OIL LUBRICATION SYSTEM IN REFRIGERATION COMPRESSOR OF R-22 OF CAPCITY 27 TR.
    Somerset
    69
    4,706
    Question Re: Oil circulation system in Reciprocating refrigeration system
    Quote Originally Posted by patilvasudeo View Post
    Dear sir,
    Do you meen the Oil Lubrication system within a specific Compressor (recip or screw?)
    What make Compressor and type would decide as to what the relevant Oil Circuitry looks like.
    Before I or anyone else can help we need more Info.
    Feb 2006
    netherlands
    5
    do you mean: the max contain of R22 in you lubrication ol to the compressor. to answer this i need to know the type of oil and the temperatures after the compressor, just before the oilseparator and the temperature from the oil into the compressor.
    best regards
    Martin Wierbosch martin@rm-support.nl
    Nov 2006
    INDIA
    10
    Dear sir,
    We have two reciprocating compressor of R-22, i would like to know oil ciculation system
    Split Croatia
    57
    6,151
    36
    Dear sir,
    It is not clear what you want to know. Describe more your problem.
    Jul 2001
    Sydney, Australia
    753
    basic oil circulation system would be something like...
    strainer, oil pump, crankcase, strainer, oil pump, crankcase
    with the odd
    carry over into discharge, oil separator, high side float, sightglass, crankcase.... then refer to first line.
    and even less
    carry over into discharge, oil separator - oops got thru, condenser, mix with liquid in reciever, expansion device, evaporator, suction line, crankcase.... back to first line.
    what I'm trying to highlight is more info is required on your behalf, the question you ask is very open to interpretation. Are you looking for what items you need to successfully return oil to your compressor? We need system application (AC, refrig - MT or LT)
    ...and she said "give it to me you big fridgie"
  1. Single stage refrigeration system optimizing diagram
    By autt in forum System Optimization
    Last Post: 03-12-2008, 03:13 PM
  2. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
