Thread: Mix, replace R22
15-01-2008, 12:36 PM #1
Mix, replace R22
Hey everyone
this is Learner.. currently in Bulgaria
My parents have been importing heat pumps for several years now. The HPs use R 22.
Can we discharge it - R22 - and replace it with
R 417?
can we mix R22 with R 407 ?
thank you for your help!
have a peaceful day!
Learner
15-01-2008, 02:42 PM #2
Re: Mix, replace R22
firstly you NEVER discharge R-22 to the air, have it recovered. Secondly R-290 is a replacment for R-22 that offers some good benifits, but it must be used by only trained peoples as it can be verry dangerous if poorly don.
The system must be solid and leak free, it must be well vacuumed (500 microns or better) this is true for any refrigerant!
R-290 (Propane) is a nice low energy consuming refrigerant that is safe for our air!
16-01-2008, 12:59 AM #3
Yes you can replace R22 with R417a but you cannot mix refrigerants.
22-04-2008, 05:23 PM #4
you cant mix refrigerants but
by my experience you can fill R22 into R407C sistems but just about 10%, but you cant fill R407C into R22 sistems
28-03-2010, 08:23 PM #5
I think you can fill R22 with R407C but i must change filter dryer and the oil in the system...
31-03-2010, 01:52 PM #6
is using R-290 actually approved anywhere in the world for domestic air-conditioners?
ive done some experimenting with it, but found it does not like to pick up the oil very well, esp in systems where the evaporator is lower than the compressor physically. even with oil traps oil makes its way down to the evaporator and stays there with straight Propane....
-Christopher
direct replace r12
By krjalone in forum RefrigerantsReplies: 12Last Post: 08-03-2009, 08:56 AM -
Compressor replace
By tralex in forum FundamentalsReplies: 12Last Post: 06-02-2009, 12:40 AM -
Top up or replace refrigerant
By chillyblue in forum RefrigerantsReplies: 24Last Post: 23-07-2007, 09:11 PM -
r290 replace
By evanlivingston in forum RefrigerantsReplies: 14Last Post: 24-05-2007, 03:31 PM -
compressor replace
By jaison in forum Trouble ShootingReplies: 3Last Post: 23-05-2007, 07:46 PM
