Results 1 to 2 of 2
    Lane's Avatar
    Lane Guest
    Help with cooling a residential draft beer set up
    I'm working on a project in my home - setting up a draft beer system. I've been using a small commercial refer but it doesn't have adequate cooling capacity. The space to put this in is really small, so I'm thinking of building an insulated box and cool it with an externally mounted compressor, etc. I also need to cool the lines going to the taps, which I've ducted inside a 2" ABS pipe, about 6 feet long.
    Is there a cooling system that I can mount externally behind my box and route the cooled air into it.... or something along those lines?
    Thanks for the help
    11,025
    Re: Help with cooling a residential draft beer set up
    Are you trying to keep the kegs cool or simply trying to serve cold beer?
  1. Compressor loading, cooling, and range of operation.
  2. draft beer dispensing equipment
    By tsounos in forum Commercial
    Last Post: 30-05-2007, 09:39 PM
  3. Draft beer dispenser
    By botrous in forum Technical Discussions
    Last Post: 23-01-2006, 10:54 PM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
  5. Draft Beer System Help
    By PAXFREON in forum Legal-Business-Marketing
    Last Post: 17-12-2004, 10:41 PM
