Thread: Refrigeration panels/Monoblocks
08-01-2008, 10:39 PM #1
Hi i am a first timer and eventually figuered it out how to send a message.Im looking for cam lock panels that is easy to take apart and put together.This is to make a different size cooler at times of need.Im also looking for a portabel,lightweight cooling system of about 5kw -7kw to fit.I have looked at zanotti monoblock units.Is there any other i can look at?
09-01-2008, 05:28 AM #2
Re: Refrigeration panels/Monoblocks
You can check with DC Systems , Denmark who are making lockable panels & we have been using them for last 12 years & are of very good quality. EFC is a company located in Spain they are also making ref units as per your needs. Similar to Zanotti. That also we are using over 12 years & have found very good.
09-01-2008, 12:07 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Misa Italy, they have panels and split type units.
http://tinyurl.com/2tj458
04-02-2008, 04:03 PM #4
CARS UK in stoke supply KOBOL monoblocks they seem very very good.
04-02-2008, 08:06 PM #5
Hey buddy...Try the supplier SRW,they had a few brands the last time I ordered a cold room from them.Hope this helps....
04-02-2008, 08:07 PM #6
Try Rivacold cold rooms,they're also ok...
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM
