Results 1 to 8 of 8
    Apr 2004
    Romania
    52
    10
    Smile refrigeration software
    Hallo Abdulazman,
    You talk about an refrigeration software ( Sabroe Techmaster). I'm interested if this software can help to calculate the liquid separator capacity for NH3 plants.
    Best regards,
    Mihai
    Mar 2005
    638
    Re: refrigeration software
    Are you asking about retention volume or separation/velocity capacity?
    I have never found a program that I would trust to calculate separation data. I prefer to do it the old long hand method.
    Ken
    poor's Avatar
    poor Guest
    I need the program
    Mar 2005
    638
    The problem with softwear is how well the programer knew his business and if he placed the proper stops in the program.
    I do not recommend that you depend on someones unknown softwear to design a separation vessel unless you know in advance how to design it yourself. Ther are just too many varriables here to consider.
    Ken
    Auckland
    74
    3,357
    37
    I agree with TXiceman. That there are too many variables to consider, and would recommend a system manufacturer for advise. But if you can access the York design program it would be half helpful only if you know the pitfalls.
    magoo
    baskaran's Avatar
    baskaran Guest
    I am problem in my system, the system running for -10 deg and -40 deg how can i separate the oil from the system, the refrigerant using R22
    THE SURGE DRUM volume is 6tons each where i trap vessel for oil rectification
    baskaran's Avatar
    baskaran Guest
    How can i select the plate heat exchanger parallel flow or counter flow which one more efficient, i seen may of the industry the using parallel flow PHE for eveporator pls give me the proper technical reason?
    omarzyead's Avatar
    omarzyead Guest
    thank uuuuuuuuuuu
  1. advanced refrigeration technology
    Last Post: 16-02-2011, 05:22 PM
