Results 1 to 1 of 1
03-01-2008, 09:19 PM #1
r134a question, calculating heat lost by refrigerant
Hi all im new to this forum, so please excuse me if this is a newbie question. I have been at this for hours, basically I have a question, I know the correct formula to use, but dont know how to apply it. here goes:
in an R134a refrigeration plant, the refrigerant leaves the compressor at a pressure of 8.87 bar and at a temperature of 45c.if the mass flow of the refrigerant is 10.2kg/min, and the mass flow of condenser cooling water is 43kg/min, find:
i) the heat lost by the refrigerant in the condenser
now i know I have to use the formula
mass flow rate of refrigerant x (h2 - h3)
I begin by making a basic table of properties as below , but im not sure where to go from here.
any help to pointin me in the right direction would be helpful
thanks all
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 01:39 PM -
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 08:49 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM
