03-01-2008, 07:32 PM #1
chart for PVC pipes closed chilled water system
Hi all,
I'm trying to find the chart for the correct pvc sizes to be used per ton of chilled water cooled system taken in consideration friction losses
03-01-2008, 10:47 PM #2
Re: chart for PVC pipes closed chilled water system
I'm not sure pvc is suited for pressurized chilled water systems. A suited material would be ABS. Your supplier should have flowcharts and pressure tables for the abs pipes!
04-01-2008, 03:53 PM #3
Iv'e always used ABS for chilled water also, i think it has a better impact resistance when its cold than PVC.
05-01-2008, 05:16 AM #4
I have no qualms using schedule 80 PVC for chilled water.
There is no chart, but try and limit yourself to flows of 4 feet per second or less.
14-11-2009, 03:23 AM #5
PVC is not really suitable, ABS is an improvement, HDPE pre fabricated, pre-insulated, is the way forward nowadays
air washer system with chilled water
By smpsmp45 in forum FundamentalsReplies: 16Last Post: 02-11-2007, 06:28 AM -
Chilled water system
By Rabindra in forum Air ConditioningReplies: 6Last Post: 23-10-2007, 08:06 AM -
Chilled Water A/C System.. antifreeze or no?
By WangFu in forum Technical SpeculationsReplies: 17Last Post: 09-08-2007, 10:36 AM -
Inhibitor for Chilled Water system
By Electrocoolman in forum Air ConditioningReplies: 2Last Post: 24-06-2007, 10:53 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
