Results 1 to 9 of 9
    Jan 2008
    India
    30
    8
    multistaging??? cascading????
    why cant i make a post.
    it always says
    "You are only allowed to post URLs to other sites after you have made 15 posts or more."
    Split Croatia
    6,103
    7
    30
    Re: multistaging??? cascading????
    Quote Originally Posted by ank_gl View Post
    it always says
    You just made post!
    Read forum rules!
    69
    10,480
    it always says
    Why do you need to post a URL, try using a question first.
    Don't complain, work around it like everyone else has done.
    Jan 2008
    India
    30
    8
    i didnt use a URL, i only typed my question, still it didnt get uploaded, anyways i ll try again. i typed everything, right from my problem to the answer, i think, but it didnt get posted. now i have to run to my college, ie, i have precisely 2 minutes. here goes
    what is the difference between multistage and a cascaded refrigeration system? and when to go for multistaging and when for cascading?
    And sir, not trying to be offensive, but i DID not use any URL, and it still showed that msg
    Apr 2001
    72
    5,069
    28
    In a multi-stage system, the compressor cylinders are in series. The vapor is pumped by half of the cylinders, the discharge of which is then pumped by the other half of the cylinders. It is far more complex than this, but essentially that's how it works.
    In a cascade system, there are two (or more) complete systems connected by an interstage heat exchanger. The interstage acts as a condenser for the low stage system and an evaporator for the high stage system. In other words, one system cools the other system which cools the product.
    A multi-stage system can achieve lower temperatures than a conventional system, and a cascade system can achieve lower temperatures than a multi-stage.
    malaysia
    159
    11
    i have attached something for you ...
    to me, multistage has some drawback.
    1] relatively high discharge pressure
    2] relatively low suction pressure
    3] uneven oil distribution
    cascade overcomes the above. ...
    the beauty is u came have different refrigerant for cascade.
    but, you need to be careful on condenser/evaporator due to its temperature differences in between ...
    hope that helps.
    Attached Files Attached Files
    69
    10,480
    Do you have a signature containing a URL ?
    Jan 2008
    India
    30
    8
    Thanks a lot Mr Gary and Mr Henry.
    I actually first posted this question on physicsforums. there i didnt get any reply. i described it completely there. actually i was confused between three situation.
    1-Multistaging = 2 cycles with same refrigerant coupled via a heat exchanger.
    2-Multistaging = Single cycle with a multistage compressor(to increase the volumetric efficiency at higher pressure ratio)
    3-Cascading = 2 Cycles with different refrigerant
    And Mr Brian, i don't have any signature, all i did was type a long question, but it didn't get posted. Anyways thats not any issue.
    I recently started working in refrigeration topic under my professor, so i hope this forum ll be more than helpful for me
    Oct 2003
    56
    5,519
    28
    It's mostly in an uneven proportion: 4 cilinders HS and 1 LS or 6/2. Mostly an interstage cooler between LP and HP to avoid high discharge temperatures.
    Ank_Gl, regrading your last post, 1 is wrong only one cycle, 2 is correct and 3 is also correct
