Results 1 to 1 of 1
    kamikazi929's Avatar
    kamikazi929 Guest
    r134a question, calculating heat lost by refrigerant
    Hi all im new to this forum, so please excuse me if this is a newbie question. I have been at this for hours, basically I have a question, I know the correct formula to use, but dont know how to apply it. here goes:
    in an R134a refrigeration plant, the refrigerant leaves the compressor at a pressure of 8.87 bar and at a temperature of 45c.if the mass flow of the refrigerant is 10.2kg/min, and the mass flow of condenser cooling water is 43kg/min, find:
    i) the heat lost by the refrigerant in the condenser
    now i know I have to use the formula
    mass flow rate of refrigerant x (h2 - h3)
    I begin by making a basic table of properties as below , but im not sure where to go from here.
    any help to pointin me in the right direction would be helpful
    thanks all
  1. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  2. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  3. frostles heat pump
    Last Post: 31-03-2008, 07:53 AM
  4. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  5. R134a <-> liquid heat exchanger design
    Last Post: 10-05-2002, 08:36 AM
