Results 1 to 9 of 9
    Mar 2002
    Spain
    67
    23
    Number teeth rotors screw
    Hi;
    I´m looking for information about number teeth rotors in the screw compressors; avantages / dis.
    The only thing i´ve got is for example:
    Howden 4/6 combination symetrical profile
    Mycom 4/6 asymetrical profiles
    Bitzer 5/6 5/7 different diameter of rotors
    Same for Grasso 5/6...
    Some more info, please
    Volos, Greece
    Re: Number teeth rotors screw
    About Bitzer try http://www.bitzer.de/eparts/index.php eparts software has a lot of informations
    Mar 2005
    638
    Generally the larger and older machines tend to run 4/6 rotors. The smaller and newer machines will be 5/6 or 5/7.
    Ken
    Aug 2005
    5,302
    There are also some different rotor profiles, but I would not worry too much about this.
    Another bit of information relates to the L/D ratio (length to diameter). A smaller L/D ratio means the rotors can be a bit stiffer therefore they will not flex very much at high pressure ratios. A compressor with a high L/D ratio such as 2.2 might have some limitations.
    The compressor manufacturers can provide more info if you need it.
    malaysia
    159
    Quote Originally Posted by Friobernal View Post
    Hi;
    hi there!
    coudl you share wit me in particular the urge for its advantage & disadv?
    unless you are very much involve in R&D of screw compressor.
    i know Bock is into this lately ....
    thanks.
    Mar 2005
    638
    I believe you are going to find that the manufacturers hold this type information very close to their chest. SRM was the primary designer of rotor profiles for a long time. A lot of the manufacturers have gone off on their and developed their own design profiles and rotor counts.
    Ken
    Mar 2002
    Spain
    67
    23
    That´s exatly what i got from the manufacturers, and why i ask here...
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, Friobernal
    I'm not sure if my answer will satisfied you, but...
    today we can find screw compressors with different rotor profiles and configuration i.e. no of teeth 2/3, 3/5, 4/5, 4/6, 5/6, 6/7 all of them calculated and invented for different type of work...dry, oil-flooded.....for air or chemical gases or for refrigeration...
    ...as per my knowledge with different (optimized) rotor profiles you can achieve better capacity with lower power consumption if you choose the right one for your needs.....here we are speaking about couple of % of better performance for the same size, speed, suction and discharge pressure between general and optimized rotor profiles...
    ....I am not too familiar with, but in my opinion this is very important only for screw compressors designers and producers and not for customers because at the end of the day we are looking for reliable machine easy and cheap for maintenance...the same as we are looking for a good car.....
    Best regards, Josip
    Feb 2006
    netherlands
    5
    Hi;
    depands what you looking for. If you looking for benefits about performance between the systems. you must look in contruction of the unit. if you have many conditions there are many ways to complise this. It is like a car , the best engine make not the best car for your expentations.
    Best regards
    Martin Wierbosch rm-support. Martin@rm-support,nl
  1. VSD on screw machines
    By Mike Hopkins in forum New Technologies
    Last Post: 20-02-2011, 12:10 AM
  2. Replies: 7
    Last Post: 23-09-2008, 09:24 AM
  3. Autoloading slide valve for Screw compressor
    By screw_geek in forum Industrial Compressors
    Last Post: 04-04-2008, 03:47 AM
  4. Filter-drier part number question
    By Larry2 in forum Fundamentals
    Last Post: 24-11-2006, 05:46 PM
  5. Mono or twin screw
    By Nirmalya in forum Industrial Compressors
    Last Post: 12-09-2006, 03:19 AM
