Thread: watercooled condenser P/D
20-12-2007, 02:44 AM #1
Happy Holidays to everyone,I have a question about watercooled condensers on a closed loop system.Whats a good pressure differential across the inlet and outlet? Current numbers are 60 psi inlet/54 psi outlet @66 f. Is there a standard ? Head pressure ok .
20-12-2007, 12:53 PM #2
Re: watercooled condenser P/D
2 pass or 4 pass? what mfg? the PD will be affected by the flow rate. You should be able to get the design criteria from the manufacturer
...and she said "give it to me you big fridgie"
24-12-2007, 04:17 AM #3
to us here, not much on standard but reasonable practices.
currently, i'm using the yardstick of 1barG. why?
imagine ... brand new s&t condenser has this value but if aging comes into place & water treatment is not relaible ....
next, i'll also consider the circulating pump's capacity. higher head higher running $.
most cases here, i'll keep the pump head below 5barG. probably 2HP or so.
Condensor split temperature
By Peter_1 in forum FundamentalsReplies: 14Last Post: 31-07-2011, 05:49 PM -
method to design air cooled condenser
By abbasi in forum New TechnologiesReplies: 4Last Post: 12-02-2008, 08:34 AM -
Optimum condenser fan speed
By star882 in forum FundamentalsReplies: 4Last Post: 27-02-2006, 01:50 AM -
Cooling condenser of split with condensate from evaporator
By smileypete in forum Air ConditioningReplies: 11Last Post: 10-07-2005, 08:21 AM -
Condenser Fan
By Vicky in forum Supermarket RefrigerationReplies: 3Last Post: 20-04-2005, 08:38 AM
