15-12-2007, 10:46 PM #1
A controller for boat refrigeration
I just joined today.
I'm looking for a controller for my boat refrigeration. I have an Adler Barber cold plate with a Danfoss compressor. The existing mechanical thermostat does not have a good temperature adjustment and no hysteresis adjustment.
I started looking at the Carel 33 12V controller but could not find out how much current it draws. I'm on a sail boat and have to run the engine to charge the batteries and so I have power usage concerns.
Is the controller current draw relatively low with & without a relay picked? My refrigeration draws 6 amps for about 6-8 hours a day. Or should I look for a different mechanical thermostat? I like the electronic type so I could read out the temperature and have an alarm when the frig/freezer temperature is too high.
What brand of thermostat/controller (mechanical or electronic) would you suggest?
16-12-2007, 03:45 PM #2
Re: A controller for boat refrigeration
Please check dixell controllers and if cant find one ask me .
20-12-2007, 09:36 PM #3
Look on carel website for info, it will not be any more than 50va
10-01-2008, 03:30 AM #4
I guess you know the thermostat circuit on the Adler-Barbour (Danfoss BD series compressor) provides no DC power to the thermostat, so you need a separate DC power source. Otherwise the Carel thermostat would work.
10-01-2008, 11:07 AM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
You should consider Elliwell EWPC 961. It is low consumption (less than 3Watt) electronic thermostat ideal for that purpose and it is 12V AC or DC.
http://tinyurl.com/2tvzro
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM
