    Nina K's Avatar
    Nina K Guest
    Amana fridge is freezing!
    My Amana side to side fridge/freezer is freezing everything in the fridge side. I've tried cleaning underneath the appliance, which was incredibly dusty, but it's still below zero even though it is set to 4 degrees. Can anyone help? thanks
    ded_maroz's Avatar
    ded_maroz Guest
    Re: Amana fridge is freezing!
    check the blade for the cold air from freezer or the thermostat driving the blade motor(if it's whith termostat )
    Nina K's Avatar
    Nina K Guest
    Thanks. I think the problem is down to something else. There is a loud buzzing noise from the freezer compartment, when you open the freezer door the noise stops and you hear a motor or a blade winding down. So the noise is coming from the motor or the blade. What do I do now?
    IL
    13
    Whats Your Excat Model ?
  1. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  2. Fridge part of frost-free fridge-freezer icing up?
    By rumpelstiltskin in forum Domestic
    Last Post: 01-06-2010, 09:56 AM
  3. Amana fridge freezer
    By fridge-man in forum Domestic
    Last Post: 09-04-2007, 10:50 AM
  4. help- my bar fridge is wacko?!
    By ben in forum Trouble Shooting
    Last Post: 25-01-2002, 12:06 AM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
