Thread: Defrost hot glycol?
21-03-2003, 05:53 PM #1
Defrost hot glycol?
This time my question is very short:
Could anybody explain me the circuit of a hot glycol defrost?
Step by step, please
Bye
21-03-2003, 06:14 PM #2
Relatively pure glycol is continuously sprayed on the coil, absorbing the moisture as it forms, then the glycol is heated to remove the moisture and pumped back to the coil, etc.
http://www.niagarablower.com/nofrost.htm
21-03-2003, 09:06 PM #3
Hi Friobernal,
Hot (warm glycol) is used on wet systems. During refrigeration the room coil is cooled with chilled glycol, during defrost the warm glycol mains is diverted through the cooler for defrost.
This glycol is heated by haet reclaim from condenser de-superheaters or more usually heat reclaimed whilst cooling screw compressor oil circuits.
Systems such as this are employed in large Regional distribution Centers for supermarkets, with NH3 being the primary refrigerant.
Regards. Andy
Milk getting into glycol on chill press
By balerjoe in forum Trouble ShootingReplies: 16Last Post: 06-09-2005, 09:41 PM -
Hot Gas defrost suction pressure regulation
By 87mustang in forum Technical SpeculationsReplies: 5Last Post: 05-08-2005, 07:25 AM -
Glycol water valves
By eng_ab in forum IndustrialReplies: 2Last Post: 03-06-2005, 09:15 PM -
Hot Gas vs. Electric Defrost
By herefishy in forum Technical DiscussionsReplies: 26Last Post: 08-03-2005, 07:50 PM -
which glycol to use ?
By dchatta in forum RefrigerantsReplies: 4Last Post: 12-07-2004, 09:26 AM
