Results 1 to 2 of 2
Thread: Flash Gas
    Dartmouth, NS
    3
    Flash Gas
    How do I calculate the mass flow of vapor being produced by flashing NH3 from a HPR to a Flash Tank?
    I know I need 1482 lbs/hr of 25°F liquid to send to the LPR so I need 1482 lbs/hr of 90°F liquid + flash gas to send to the Economizer from the HPR. The economizer suction will see 767 lbs/hr from the low temp. evaps + this flash gas. I'd like to be able to calculate it by hand.
    Not worried about defrosting at this point.
    Steve
    mag1969's Avatar
    mag1969 Guest
    Re: Flash Gas
    By my calculations... 228.4 lbs/hr.
    Always ask yourself, how much energy does it take to cool 1482 lbs/hr of liquid ammonia from 90 to 25?
    Now that you know the ammount of energy you need. Then ask yourself, how much mass of ammonia would i need that would absorb this ammount of energy from a phase change from 90 degrees F liquid to 25 degrees F vapor.
    Simple problem if you break it down.
  1. flash gas
    By bandit in forum Fundamentals
    Last Post: 19-09-2010, 06:21 PM
  2. shining fault codes
    By al in forum Air Conditioning
    Last Post: 17-07-2010, 08:34 AM
  3. Effect of Hot Gas and Flash gas on Evaporators
    By NH3LVR in forum Technical Speculations
    Last Post: 14-08-2007, 05:58 AM
  4. Evaporator Flash over
    By Chef in forum Fundamentals
    Last Post: 25-06-2007, 11:02 AM
  5. Replies: 1
    Last Post: 16-12-2003, 12:33 AM
