Thread: Oils
    Feb 2003
    uk
    52
    13
    Oils
    CAN ANY ONE HELP,
    I NEED TO KNOW WHICH OILS ARE BEST USED WITH:
    AMMONIA @-40C
    R22 @-15C
    R134a @5C
    AS AM GETTING ALLOT OF CONFLICTING INFORMATION REGARDING FLOC POINT OF AMMONIA AT THIS TEMP,
    ALSO THE R134a SEEMS TO BE STATING SEVERAL DIFFERENT TYPES.
    ANY HELP WOULD BE GLADLY RECEIVED.
    THANKS
    JOHN M
    BR, john
    Sep 2006
    Manila
    12
    Re: Oils
    For R22 Low, Medium, High Temp ,the recommended oil is Mineral oil. For R134a Medium & High Temp, the recommended oil is POE.
    Jul 2006
    New Berlin, Wisconsin, USA
    65
    57
    Re: Oils
    For Ammonia at -40c you should stay away from mineral or Hydrotreated mineral oils as their pour point is too high about -31c. Maybe look at a PAO for the low temp application.
    Aug 2001
    NE Lincolnshire, UK
    145
    23
    Re: Oils
    Quote Originally Posted by johnemar View Post
    CAN ANY ONE HELP,
    AMMONIA @-40C
    R22 @-15C
    We used a hydro-treated PetroCanada Reflo 68A with very good results on Ammonia at -40C after problems with standard mineral oils thickening up and high oil carry-over. The higher cost was offset by reduced oil carry-over. We carried out extensive monitoring over two years before fully converting. Sabroe recommended we tried the oil.
    R22, use standard mineral oil.
    Steve
    ahmadwahidi's Avatar
    ahmadwahidi Guest
    Re: Oils
    for screw compressor which oil can used if the ***** is R22
    Oct 2009
    merida mexico
    282
    15
    Re: Oils
    oil mineral
  1. refrigeration oils
    By dumpeyau in forum Fundamentals
    Last Post: 18-11-2009, 11:00 AM
  2. Refrigeration oils
    By johnemar in forum Refrigerants
    Last Post: 25-02-2003, 07:36 AM
  3. low PH oils
    By pirestani in forum Refrigerants
    Last Post: 24-10-2002, 08:05 PM
  4. R-22 with ester oils
    By Friobernal in forum Technical Discussions
    Last Post: 24-05-2002, 05:11 PM
  5. HCFC refrigerants, oils etc.
    By subzero*psia in forum Technical Discussions
    Last Post: 08-03-2001, 12:19 AM
