Thread: Exam
    Zamman's Avatar
    Zamman Guest
    Exam
    I'm studying for an exam. Could someone please describe a "two stage centrifugal chiller"
    Aug 2005
    5,302
    Re: Exam
    Usually when you discuss centrifugal compressors they are referred to as single or multiple stage. A single stage compressor only has one wheel or impeller. A multiple stage compressor has multiple wheels. Therefore, a two stage compressor would have two wheels or actual impellers in the compressor housing.
    Apr 2006
    Torquay
    59
    130
    Re: Exam
    Two impellors, one in front the other, a bit like a multi stage water pump.
    Aug 2001
    1,046
    Re: Exam
    The compressors are arranged in series, usually in a common housing; therefore the discharge gas of the first stage enters the suction of the second and so on.
    They are generally very high capacity chillers, several megawatts – do a Google on Carrier 17 series open drive chillers to see some examples.
    Nov 2005
    New Zealand
    550
    Re: Exam
    Hi Best Way to do this is Google carrier 19FA compresors as Iceman says they have double high speed impellers and have what the call Labyrynth seals between the stages, they usualy suck gas from an econimiser it mixes with the first stage gas then pumped to the condensor. If you look up 19C or 19DG they are single stage and you can compare them. Hope this explains a bit about them
    regards NORM
    My wife used to say you never listen to a word I say at least I think that what she said
    Zamman's Avatar
    Zamman Guest
    Re: Exam
    Thanks guys you are a big help!
  1. Heat Transfer Exam Question
    By alexdouglas1969 in forum Fundamentals
    Last Post: 13-12-2008, 04:19 PM
  2. RE exam.... any hints or tips?
    By Dnipro in forum New to RE
    Last Post: 03-02-2007, 01:40 PM
  3. Maths Exam (from the USA) - I believe!
    By frank in forum Chit Chat & Service Stories
    Last Post: 17-11-2006, 08:36 AM
  4. Exam
    By bernard in forum Chit Chat & Service Stories
    Last Post: 21-07-2005, 01:40 AM
  5. Ontario "A" exam
    By Paul K. in forum Training
    Last Post: 10-04-2005, 10:39 PM
