Results 1 to 18 of 18
Thread: Hydro Cooler
08-12-2007, 12:09 AM #1
Hydro Cooler
I would like to know, how to determine the product temp. coming out of the hydrocooler, when time and water temp is know.
For eg, We need to design Hydrocooler to cool Blueberries.
Incoming temp is 80F and water is 35F.
Product on the belt @ time -- 110 Lbs
Time to travel belt from one end to other -- 1 min.
Water Flow rate -- 70 GPM.
Need to know the temp. that can be achived with the above scenario.
Thanks in advance.
08-12-2007, 12:35 PM #2
Re: Hydro Cooler
Try speaking to an engineering firm, and be prepared to pay for their knowledge
...and she said "give it to me you big fridgie"
09-12-2007, 09:22 AM #3
Re: Hydro Cooler
Temperature of the air can be plotted in a psychometric chart.
If you want to know the product temperature, only a test can give you the right answer because there are to many uncertainties (belt width, speed, wind circulation, thickness of the product on the belt, the physical properties of the product,..)It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
09-12-2007, 07:41 PM #4
Re: Hydro Cooler
The cooling medium is water and not air.
Any suggestions!!
09-12-2007, 07:46 PM #5
Re: Hydro Cooler
You are spraying cold water over the products, is this correct?
You see, you questions could be misunderstood.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
10-12-2007, 03:42 PM #6
Re: Hydro Cooler
Yes Sir,
Its Hydro Cooler, cold water will be sprayed/rained over the warm product.
Regards,
11-12-2007, 05:22 AM #7
Re: Hydro Cooler
hydrocooler? Where are you geting your termonology?
Chilled water system is what your talking about? and by the sounds of it a verry big one.Last edited by The MG Pony; 12-12-2007 at 03:12 PM. Reason: put a "." where I meant to put a "?"
12-12-2007, 02:21 AM #8
Re: Hydro Cooler
Hydrocooler is a correct and proper term. It's essentially a water chiller where the cold water is sprayed over fresh picked vegetables/fruit to cool them down quickly.
For leafy products, vacuum cooling is mostly used.
The original posted question relates to a heat transfer problem that is not too simple to solve.If all else fails, ask for help.
12-12-2007, 03:49 AM #9
Re: Hydro Cooler
Thanks US Iceman,
Any approx. suggestions will be highly appreciated.
12-12-2007, 03:10 PM #10
Re: Hydro Cooler
thats why I asked where he got the term from, I've never heard of it refered to that, I've heard of such systems refered to as trough chillers, one fellow used such a set up for his tomato farm, tomatoes lowered into a channel of chilled water allowed to float down the line and back onto the belt.
I do know of the spray type, a loos weaved bealt the product rides on through a sprinkler system of chilled water, they just all refered to it as a spray chiller.
Or is there no real naming standered to them?
13-12-2007, 05:41 AM #11
Re: Hydro Cooler
Originally Posted by The MG Pony
jwasir, part of the problem is determining the transient heat transfer conduction from the berry to the cold water, and then finding the rate of temperature increase in the water.If all else fails, ask for help.
13-12-2007, 10:24 AM #12
Re: Hydro Cooler
Yes , hydrocoolers are becoming more and more a significant 'link' in the immediate post harvest cold chain.
As we said recently " from farm to fork" continuity of good practice.
This link will give some of the players in the equipment manufacture etc.
http://postharvest.ifas.ufl.edu/Post...rigeration.htm
As 750 Valve rightly said, expect to pay for consultants but this gentleman, Dr Pat Brecht is one we have worked with on post harvest research.
http://www.pebcommodities.com/news.htm
hope this is helpful, references given without any bias.
regards
T-PRemember what Augustus once said:
"festina lente" - make haste, slowly!
13-12-2007, 10:52 AM #13
Re: Hydro Cooler
There are different methods of Pre Cooling of Post Harvest produces. These depends on the produces to be cooled. Hydrocooling is one of the methods. I have the details of this system. I shall try to locate the same and have the same submitted on the forum.
13-12-2007, 11:50 AM #14
Re: Hydro Cooler
The following link may be helpful. Please download the same immediately.
http://download.yousendit.com/3D7AB8F9726C93B4
13-12-2007, 09:26 PM #15
Re: Hydro Cooler
Thank you Samarjit. This looks like a very good resource.
14-12-2007, 04:56 PM #16
Re: Hydro Cooler
Thanks Mr. Sen,
This really is very infrormative.
Regards,
06-01-2010, 05:09 AM #17
Re: Hydro Cooler
my company specializes in building custom hydrocoolers, you will need to take approx 3 minutes @ 32 33F water showering. a bordlot style coil suspended about the shower, some call it an ice bank. I would use a 5 hp condensing unit with a custon refrig coil, 12 curcuit coil @ 8 rows of pipe use 5/8 rigid and control your pumpdown with an ice sensor located approx a quarter inch from the copper thus building ice till it touches sensor, ice melts and system fires back up again.
jesse.
11-02-2010, 07:32 PM #18
mojonnier carbo cooler common system
By guapo in forum IndustrialReplies: 9Last Post: 16-06-2011, 05:20 PM -
NH3 thermosiphon oil cooler
By cygbob in forum NH3Replies: 38Last Post: 22-06-2008, 05:12 PM -
TXV hunting in a walkin cooler
By dkemper in forum Trouble ShootingReplies: 9Last Post: 15-11-2007, 03:14 PM -
Walkin cooler
By masooda in forum Trouble ShootingReplies: 4Last Post: 09-02-2007, 04:57 PM -
Thermo-syphon Oil Cooler
By B.B. in forum IndustrialReplies: 5Last Post: 31-10-2005, 01:25 PM
