Thread: 1/4 Flare Flexable Gauge Lines.
06-12-2007, 06:14 PM #1
Hi Guys.
Can anyone help? I removed a flexable 1/4 flare gauge line, connected to a brazed schraeder port. On H.P. Liquid line. Feeding a H.P. Pressure switch, changed the faulty pressure switch.
When I came to refit the line there was no schrader decompression fitting in the line? All I could see was a female flare seat.
I assume I had managed to loose the fitting!
Can anyone advise as to where I can get a replace ment?
Also what do you call these little bliters.
Pressumeably they are similar to the removable decompressors in newly bought gauge lines.
Grizzly.
PS I don't know if it is relevant but it was on an Italian Chiller.
To get over the problem I cracked open the schraeder valve from it's seat and re-attached the gauge line. Leaveing a label on it warning other Engineers that the schraeder is cracked open (passing) as a temporary measure.
06-12-2007, 06:34 PM #2
Re: 1/4 Flare Flexable Gauge Lines.
Most of the major suppliers (HRP, D&W, CC and so on) will sell them, I don't know what the proper name is but when I ask for "a schraeder depressor that sits in a 1/4" flare" they knows what I mean.
06-12-2007, 06:55 PM #3
Yo Viking.
Say it as you see it!
Apparantly my supervisor (a while back) asked the local manager of 1 of the three you mentioned and drew a blank.
Anyway I will try them again in the morning.
Many thanks Grizzly.
Does anyone feel they are called anything different?
06-12-2007, 07:05 PM #4
Theres a bit in this months 'service engineer' mag about these things (depressors). You may need to buy a new flexible hose with one already in, as you would need a depressor sized to fit exactly the hose already fitted otherwise.
Jon
06-12-2007, 07:12 PM #5
Jon.
Sounds like a temporary repair that's about to become permanent. If that's the case, customer won't pay for new lines. I will post how I get on at the suppliers. I hav'nt seen this months Service Engineer yet. I will try and pick one up tomorrow.
Cheers Grizzly.
06-12-2007, 07:22 PM #6
There is of course another alternative.
Get another fitting with a depressor in it and fit in-between the line and the system....
06-12-2007, 08:22 PM #7
See what "another pair of eyes" does.
Good shout Viking, one way or another it will be resolved tomorrow. With a trip to the wholesalers.
Cheers Grizzly
06-12-2007, 10:39 PM #8
To flare or not to flare?
By worthington in forum CommercialReplies: 15Last Post: 13-03-2010, 07:36 PM -
18kw with 7/8 flare
By wombat in forum Air ConditioningReplies: 5Last Post: 01-11-2007, 11:40 AM -
Why don't A/Cs have gas pressure gauge
By AndY1 in forum Air ConditioningReplies: 9Last Post: 04-11-2006, 11:07 AM -
Flare nuts
By Jase in forum Air ConditioningReplies: 17Last Post: 10-07-2005, 10:01 PM -
solder V Flare Driers
By Latte in forum Technical DiscussionsReplies: 45Last Post: 23-05-2004, 09:22 AM
