Results 1 to 26 of 26
Thread: Simple question
    Mar 2003
    Lincolnshire
    13
    Simple question
    I am attampting to create my own air conditioning unit from an old fridge. I live in the UK and I would like to know if it is legal to re-gas a fridge that has been taken apart. If so, can anyone tell me how much it is likely to cost?
    Many thanks,
    Matthew
    11,025
    Matthew, you should know that here in the UK we can do almost anything we like with the environment, until you get caught
    You can regas the fridge if you want or better still get someone with the correct equipment/gas to do it for you.
    Remember that the unsocial part is removing the gas from the system before you start, you should NOT vent this to atmosphere as it is illegal and bad for all of us.
    If you are using old parts (or re-using) make sure that you keep everything dry and airtight when in storage to prevent damage.
    Anyway, good luck with your project.
    Mar 2003
    Lincolnshire
    13
    Thanks Brian. I'll get it discharged properly, but before I start constructing the project I'll need to make sure it wont cost too much for getting the fridge discharged/recharged. Otherwise, I may as well go out and buy an air conditioner.
    On a further note, would there be any way to take the radiator away from the compressor with some longer flexible coolant lines WITHOUT having to discharge the fridge at all? I doubt it's possible but it's worth asking.
    Thanks again for bearing with me,
    Matthew
    Aug 2001
    Gold Coast, Australia
    600
    28
    Good morning Matthew.
    I'm afraid you can't get away without reclaiming the refrigerant.
    And if you're extending the pipe work, then you'll be significantly altering the system parameters. Pressure drops will cause problems - pipe work needs to be properly sized to correct this.
    Also, flexible pipe is not a good idea. It tends to have a relativley short life - I change my guage hoses at least once a year, for example. This means that you'll regularly be reclaiming refrigerant, replacing hoses, and recharging. It's a lot of hassle that you can easily avoid by using copper pipe.
    Apr 2001
    79
    5,071
    35
    Aside from the legal ramifications, transforming a low temperature (freezer) system into a high temperature (A/C) system would be difficult enough for the professionals, and a nightmare for the novice.
    Dec 2001
    Cleveland
    41
    Go and buy a air-conditioner
    Oct 2001
    Nottingham UK
    5,668
    Hi matthew
    It would be interesting to hear how you intend to construct an air conditioner from an old fridge. What are your plans for getting the cold air into the room?
    frank
    Mar 2003
    Lincolnshire
    13
    To be honest it's more of an 'air cooler' than an air conditioner. Basically I was thinking of using two small radiators (perhaps from a small chest freezer), with one outdoors and one indoors, and then placing a fan behing them. I also thought about drawing fresh air into the room, but i'm not too sure on the best way to do it yet.
    If it's too hard to do with refrigeration, I do have a backup plan. What I did think of was using two large thermoelectric/peltier modules. On the inside these would be sandwiched between some form of home built radiator and a large piece of metal. The large piece of metal would have copper pipes soldered onto it, with water flowing through them to carry the heat outside. This then flows through another radiator outdoors and the heat is disippated by a large fan. Of course these peltiers draw a HUGE amount of current and it would require a large transformer, not to mention the cost of the peltiers themselves. Needless to say, an old fridge or freezer would be much cheaper.
    Best regards,
    Matthew
    Jan 2003
    Buffalo, NY
    21
    Re: Simple question
    Go Buy an Air Conditioner
    Apr 2001
    2,099
    27
    Re: Simple question
    Im a copy cat,
    " Go buy yourself an air conditioner"
    This contraption will NEVER work
    Nov 2003
    North Wales
    48
    74
    21
    Re: Simple question
    Hi Mathew,
    By the time you way up all your costs for pipe work, refrigerant, the equipment to pull the system down to a vacuum the reclaim disposal cost. You might as well go and buy yourself a second hand portable a/c unit.Because you could spend all that money and it just might not work..
    Neil
    Oct 2001
    Nottingham UK
    5,668
    Re: Simple question
    The average domestic "fridge" is about 650W cooling duty and the average domestic room load is about 2500W. If you ever complete the task it will be drastically undersized and will not give any useful cooling. Saying that though, you will learn an awful lot about air conditioning - like how you have to apply the mathematics before you expend time and money
    Best of luck with the project
    frank
    Jan 2003
    Buffalo, NY
    21
    Re: Simple question
    why reinvent the wheel...can a VW beetle act as a milk truck if I reduct the a/c? I've said enough.
    Oct 2003
    5,630
    34
    Re: Simple question
    It will never work for the reasons Frank gave you
    Charnwood's Avatar
    Charnwood Guest
    Re: Simple question
    Perhaps some of the critisism could be a little more constructive in places. Matthew, I think you can tell from the bulk of the posts that this is not going to work. I admire your efforts to save a few bob, but I reckon you should give this idea a miss!
    Mar 2003
    Lincolnshire
    13
    Re: Simple question
    Wow, I didn't even realise this topic was still alive. Anyway, don't worry about the criticism, but also remember that the intention of the project was never to create a true replacement for a proper air conditioner, more as an experiment to see how well it would work.
    However, in the end I took the advice given on this forum and gave the idea a miss, so I would like to thank everyone that pointed me in the right direction. I still like the idea of using TEC's/peltiers, but it would be stupidly inefficient and expensive, so I'll have to give that one a miss as well.
    Regards,
    Matthew
    Jul 2003
    12
    Re: Simple question
    Hi all
    Does anyone know someone who wants to buy an air conditioner?
    Oct 2001
    Nottingham UK
    5,668
    Re: Simple question
    Air Conditioner? How do they work then?
  19. #19
    Oct 2004
    U.K.-London
    144
    Re: Simple question
    GO BUY AN AIRCONDITIONER
    Never underestimate anybody, you never know when they will make you look like an idiot!
  20. #20
    Oct 2004
    Australia
    64
    41
    Re: Simple question
    you have got to be kidding fist it is not designed to operate at the temps req second wat area are u cooling ur toilet as it would not have capacity to do any more third if u intend to use fresh air it wont even do ur dunny. If u live in the UK it never gets hot enough to need a/c im in australia and dont have it in my home and my car is pommy and is 1 off the only vehicles that A/C's are an option. Suggest u try a fan
  21. #21
    Nov 2004
    perth australia
    77
    14
    Cool Re: Simple question
    hi guy,s
    Re the fridge converter, forget it, it,s more trouble than it,s worth, by the time you have finished getting the bit,s and pieces and your t+l you could have go out and bought two split a/c,s, installed them and have full warranty in place.
    The penalty here in aussie for doing what you intend to do is a $10,000.00 fine if you are caught.
    There is also the distint possibility it won,t work any way.
    use the old fridge for a tool box.
    regards tony longthorne.
  22. #22
    May 2004
    64
    43
    Angry Re: Simple question
    God forbid you ever live near me with that device banging away!!!
  23. #23
    Aug 2008
    uk
    21
    Re: Simple question
    bet you wish you never ever asked...
  24. #24
    Aug 2008
    Iraq
    54
    23
    Re: Simple question
    Last edited by Peter_1; 17-08-2008 at 03:58 PM. Reason: Is much quiter now with size 3 lettertype instead of 7
  25. #25
    Oct 2003
    5,630
    34
    Re: Simple question
    Quote Originally Posted by TONY LONGTHORNE View Post
    If he's doing it legally, he can do what he wants.
    But it will not work anyhow
  26. #26
    Apr 2006
    41
    1,620
    Re: Simple question
    Quote Originally Posted by dougdotcom View Post
    4 year old thread revival! Congrates your a neckromonger!
  1. Fitting an expansion valve question
    By Larry2 in forum Air Conditioning
    Last Post: 08-04-2008, 04:17 PM
  2. Newbie with a question
    By AcidSlasher in forum Fundamentals
    Last Post: 07-03-2006, 11:20 AM
  3. quizy type question thingy
    By rbartlett in forum Chit Chat & Service Stories
    Last Post: 06-02-2006, 09:22 PM
  4. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
  5. Direct Energy Consumption Question
    By v8dve in forum Fundamentals
    Last Post: 05-04-2003, 03:31 AM
