06-12-2007, 04:21 PM #1
fault prediction from just a few lines of text ..
What follows in bold and quote is a brief description of a domestic fridges temperature regulation ..
I wonder if anyone would like to spot diagnose the likely problem here ..
"Not keeping food cold. When you turn temperture up it starts to freeze food in fridge."
My guess is that the thermostat is playing up . reasoning is
a, the compressor is working (fridge can get cold)
b, It does not seem to be related to a defrost timer issue (fault is regulated by thermostat adjustment)
My considered guess is that the contacts on the thermostat are corroded and it is switching from not cool at all at low settings to cold/freezing with nowhere in between ..
Do you think i have almost got it right ?
06-12-2007, 08:44 PM #2
Re: fault prediction from just a few lines of text ..
Sounds reasonable to me.
07-12-2007, 12:22 AM #3
Nope, I disagree.
"Not keeping food cold. When you turn temperature up it starts to freeze food in fridge."
If they can make a mistake with this then I am guessing they made a mistake here as well...
"Not keeping food cold."
So, I deduct its the freezer section that is not cold enough, so this makes them turn the stat colder and freeze the fridge section.
Evap iced up in the freezer section. or something like that.
Although I could be wrong, but that doesn't happen very often.
ChillinLast edited by chillin out; 07-12-2007 at 12:24 AM.
and go get a cuppa
07-12-2007, 10:45 AM #4
If it's a frost free fridge there's going to be two controls. Even the basic ones have an electrical thermostat in the freezer, and a mechanical damper/thermostat in the fridge. you would need to know which control they are playing with and in which compartment is the food not cold/freezing.
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
Fault with Tango cassette
By airefresco in forum Air ConditioningReplies: 8Last Post: 19-09-2007, 08:42 AM -
UA Daikin Fault Code
By jedi in forum Air ConditioningReplies: 2Last Post: 23-07-2007, 01:44 PM -
Chiller fault
By iceman007 in forum Trouble ShootingReplies: 9Last Post: 27-06-2006, 06:15 AM -
Chiller Fault
By iceman007 in forum Air ConditioningReplies: 2Last Post: 13-05-2006, 07:23 PM
