Results 1 to 2 of 2
Thread: Spiral Evaporator
05-12-2007, 07:38 AM #1
Spiral Evaporator
I have an order from consumen to made design for spiral evaporator.
I didn't know the formula for calculated that evaporator.
So i would like to ask to the forum what is the formula to calculated the spiral evaporator?
the data is :
- Cooling capacity : 36,3 kW
- Evaporating Temperatur : 0 C
- Condensing Temperatur : 45 C
the question is :
- Size for cooper tube (diameter and long) ?
- Diameter of the spiral ?
- Height of the spiral ?
- Give the dimension of the spiral evaporator ?
06-12-2007, 12:14 AM #2
Re: Spiral Evaporator
Why not measure an existing 36.3kw evaporator and use those figures?
Designing Roll Bond Evaporator
By Munzar Ata in forum FundamentalsReplies: 11Last Post: 05-08-2010, 11:31 AM -
Absortpion Refrigeration - Evaporator Basics
By knudo in forum FundamentalsReplies: 4Last Post: 28-08-2007, 08:03 AM -
What is the best location for a evaporator fan?
By Jasno999 in forum FundamentalsReplies: 3Last Post: 21-02-2007, 12:34 AM -
Air Source Heat Pump - temp of refrigerant leaving evaporator
By anup in forum FundamentalsReplies: 3Last Post: 06-11-2006, 05:04 AM -
Change evaporator
By tralex in forum FundamentalsReplies: 6Last Post: 29-12-2005, 07:53 PM
