Page 5 of 5 FirstFirst 12345
Results 201 to 237 of 237
  1. #201
    Aug 2007
    racine, wi
    68
    135
    Re: 404a high pressure?
    Quote Originally Posted by flyboy3b View Post
    the box is 3/4" birch plywood with 1" foil covered foam insulation sandwiched in between. the doors are double glazed with a 1/2" space between.
    make that double 3/4" plywood
  2. #202
    Apr 2001
    79
    5,071
    35
    the duct is basically 2 - 6" galvanized elbows going from the side of the box to the bottom of the evap chamber and it is insulated.
    I would strongly recommend the insulated flexduct.
    the evap chamber is 3/4" plywood with 1 1/2 " styrofoam on the top and right side (the left side borders the cooler) and 1" foil covered foam in the back. the bottom is just plywood.
    The bottom and front should be insulated as well. Hot air rises up from the condensing unit.
    anyhow,, i checked it this morning,, and it has started cooling again and im confused. i understand that the pressures are relative to the temperatures of the ambient air, air flow, and box temperatures. but,,,,
    the ambient temps have been basically the same this whole time.
    even when the box was warm, the txv would still frost up.
    even though the superheat was really high the txv would still frost up.
    through this whole thing,, the low side pressure had never been this high.
    What I was seeing was essentially the same heat load being pumped by the condensing unit, but the evaporator load was much greater. In other words, the system was working about the same, but more heat load was entering, specifically in the return air. That return duct seems to be the achilles heel of this system.
    anyhow,, here are the new readings,,,
    ambient 76f
    box 52f
    suction line at bulb 42f
    suction at compressor 51f
    liquid line at receiver 97f
    cond air in 77f... out 86f
    evap air in 53f... out 44f
    pressures at 60 and 270 psig
    superheat 19f
    subcooling 16f
    You might want to open the TXV 1/2 turn. I would like to see the superheat back down around 12F.
  3. #203
    Aug 2007
    racine, wi
    68
    135
    im not sure how long it had been cooling when i took those measurements,, ill check it again in a little while, now that its had a chance to cool down inside the box.
    and yes,, there are adjustments i can make to tweak this cooler,, and i will. but im still miffed as to why the sudden change. as i said before,, the txv was warm. before that,, despite all the inefficiencies,, the txv would always frost up,, and the pressure (or temp) at the txv was never that high.
  4. #204
    Apr 2001
    79
    5,071
    35
    The increased heat load warms the refrigerant, increasing its pressure/temperature. The warm refrigerant (40F) is not going to frost anything.
    We know the return has been a problem all along. Why did the return suddenly decide to leak more heat than previously? I don't know.
  5. #205
    Aug 2007
    racine, wi
    68
    135
    again,, pardon my stupidity,, but right at the txv,, the heat load doesnt exist yet. does it?
  6. #206
    Apr 2001
    79
    5,071
    35
    Actually, the refrigerant going through the TXV is warm liquid which quickly flashes off to bring its temperature down to the saturation temperature (40F). So at that point it is not yet down to 40F.
  7. #207
    Aug 2007
    racine, wi
    68
    135
    but that liquid was no warmer yesterday,, than it was a week ago. wouldnt the liquid line have to be hotter to increase the pressure on the low side of the txv to where it was yesterday??
  8. #208
    Aug 2007
    racine, wi
    68
    135
    heres the latest,,
    suction line at bulb 58f
    liquid line at receiver 93f
    evap in 47f
    evap out 39f
    cond in 71f
    cond out 85f
    ambient 74f
    pressures at 60 and 265 psig
    superheat at 35f
    subcooling at 17f
    it seems like were losing ground here,, but ill check in the morning
  9. #209
    Aug 2007
    racine, wi
    68
    135
    actually,, thinking about it,, im not sure how long it had been running for when i took those temps. it may have just started before i looked at it.
  10. #210
    Apr 2001
    79
    5,071
    35
    The low side pressure/temperature is regulated by the temperature and volume of the air passing through the evaporator.
    The low side temperature (and thus pressure) was warmer yesterday because the airflow entering the evaporator was warmer.
    The warm liquid leaving the TXV must drop in temperature to match the low side temperature. It is not the cause of the low side temperature/pressure. The heat from the air is.
  11. #211
    Apr 2001
    79
    5,071
    35
    heres the latest,,
    evap in 47f
    evap out 39f
    cond in 71f
    cond out 85f
    ambient 74f
    superheat at 35f
    subcooling at 17f
    I don't think we're losing ground at all. The superheat is higher, but we know that the TXV orifice is oversized which will cause it to hunt, especially when it first starts.
    We can open it another 1/2 turn and see how that does.
  12. #212
    Apr 2001
    79
    5,071
    35
    If you want to stick with the metal duct for the rigidity, you might seal it with duct tape and then insulate it with sheet Armaflex (closed cell foam).
    An alternative would be several layers of Armaflex foam tape. Start at one end of the duct, spiral the tape around the duct, overlapping about halfway across the previous spiral, to the other end of the duct. Run the system for awhile. If the surface of the tape is cool to the touch, add another layer.
  13. #213
    Aug 2007
    racine, wi
    68
    135
    as is said before,, once i know the system is gonna be ok,, i will redo a few parts,, including teh evaporator chamber. i figure to eliminate that duct and just suspend the coil and draw air through it.
    here are the latest readings,,,
    ambient 74f
    box 41f
    suction line at bulb 34f
    liquid line at bulb 97f
    evap air in 45f out 36f
    cond air in 77f out 89f
    superheat 18f
    subcooling 15f
    pressures at 55/275 psig
    lol,, this thing is bouncing around so much. if i can get a few steady readings,, im close,, i think
  14. #214
    Apr 2001
    79
    5,071
    35
    I would give it a layer of foam tape anyway, even if it's just temporary.
  15. #215
    Apr 2001
    79
    5,071
    35
    In your pictures, it looks like the duct "insulation" is a towel. I'm wondering if it got damp enough the other day to nullify it's insulating effect, then dried out and started working again.
  16. #216
    Aug 2007
    racine, wi
    68
    135
    there is insulation under that,, and no,, ive been trying to think of what happened when it warmed up,, but thats not it,,, everything was dry.
    in my opinion,, in my vast experience,, i think the txv stuck open. it still provided enough resistance to keep the pressure under 100 psi, but not enough of a drop in pressure to provide cooling. all of the other factors seemed the same as any other day. it certainly got as warm,, if not warmer,, in the time we have been discussing that cooler. i can see no other significant differences that would cause that drastic of a change.
  17. #217
    Apr 2001
    79
    5,071
    35
    I have no idea what heated the return air, but that is what caused the problem.
    A stuck open TXV would have given us very low superheat and flooded the compressor. That didn't happen.
  18. #218
    Aug 2007
    racine, wi
    68
    135
    this mornings readings are,,,
    ambient 77f
    box 43f
    suction line at bulb 41f
    liquid line at receiver 99f
    cond air in 74f / out 90f
    evap air in 52f / 41f
    pressures at 60/275 psig
    superheat 18f
    subcooling 13f
    well,, maybe itll happen again
  19. #219
    Apr 2001
    79
    5,071
    35
    ambient 77f
    box 43f
    superheat 18f
    subcooling 13f
    Actually, the numbers are looking a little better. Try another half turn out on the TXV.
  20. #220
    Apr 2001
    79
    5,071
    35
    How is our wine cooler doing? Have we gotten the superheat down to 12F yet?
  21. #221
    Split Croatia
    6,151
    Maybe his vine is properly cooled now and he enjoy his vine finally.
    That is what I will do if that is my case.
  22. #222
    Aug 2007
    racine, wi
    68
    135
    sorry,, i just got busy. itll be a couple days before i can get back in there. but just from casual observations,, it seems to be doing ok.
  23. #223
    Feb 2007
    solihull
    hi flyboy , if its doing ok , PLEASE DONT TOUCH !!!
  24. #224
    Aug 2007
    racine, wi
    68
    135
    Quote Originally Posted by knight rider View Post
    lol,, advice well taken,, thanks
  25. #225
    Feb 2005
    Hong Kong
    190
    Whoaaaaa ? U mean this saga may come to an end ?
    NO ! pls keep on toying with it , Flyboy !!
    You've now got the " tamperitis" bug of fiddling with tx valves.
    All us avid readers around the globe need our daily fix of this thread
    Try and screw it up again so we can keep this project going .... if Gary was charging u for advice, it would have to go on record as the most expensive wine cooler in history!!!!
    yuk yuk
    regards
    T-P
    Remember what Augustus once said:
    "festina lente" - make haste, slowly!
  26. #226
    Aug 2007
    racine, wi
    68
    135
    hi honey,, im hoooome.
    sorry guys,, ive been a little under the weather. anyhow,, these are the readings i took this morning,,,
    ambient 74f
    box 38f
    cond air in 67f,, out 81f
    evap air in 46f,, out 38f
    liquid line at receiver 91f
    suction line at bulb 40f
    pressures at 50 and 255 psig
    superheat 25f
    subcooling 14f.
    i opened the txv 2 turns and ill let it settle out and take the readings again in an hour or two.
    Quote Originally Posted by thermo prince View Post
    theres plenty of time for that T-P,,, i believe its a god given right for a man to make a fool of himself,, and i excersize that right often.
  27. #227
    Apr 2001
    79
    5,071
    35
    I assume the suction line is insulated between the coil and the bulb... and the bulb heavily insulated?
  28. #228
    Aug 2007
    racine, wi
    68
    135
    let me rephrase that,, i opened the txv 2 quarter turns = 1/2 turn.
    yes,, the valve and line are insulated
  29. #229
    Apr 2001
    79
    5,071
    35
    ambient 74f
    box 38f
    superheat 25f
    subcooling 14f.
    Our superheat seems unwilling to cooperate. Is the TXV still hunting?
  30. #230
    Apr 2001
    79
    5,071
    35
    I wonder if the high side gauge is off a few psi, leading us to believe that the subcooling is higher than it actually is?
    Connect the high side gauge to your refrigerant tank. The pressure should agree with the temperature of the tank.
  31. #231
    Aug 2007
    racine, wi
    68
    135
    to be honest,, taking the suction line reading seems very fickle. sometimes i have to take the reading several times before i get a reading that seems right (i take the lowest reading).
    no,, the suction line temp is very stable (within a couple degrees). here are the latest readings,,,
    evap air in 46f (in reality this is probably lower)
    evap air out 38f
    cond air in 67f,, out 83f
    suction at bulb 36f
    pressure at 58 and 250 psig
    superheat 14f
    subcooling 14f
    give me a little bit and ill check the accuracy of my gauges (does it matter if the bottle of 404a is like 10 degrees or would it be more accurate if i warmed the bottle up?)
  32. #232
    Apr 2001
    79
    5,071
    35
    It would be better if the bottle were warmed up and stable. That way we can calibrate to a temp that is closer to what we use the gauge for.
  33. #233
    Apr 2001
    79
    5,071
    35
    superheat 14f
    That's much better. We are very close to our target of 12F.
    The low side pressure/temperature is hunting because the TXV orifice is "A" instead of "AA". The orifice is oversized.
    You are right to use the lowest readings.
  34. #234
    Aug 2007
    racine, wi
    68
    135
    i tried is with two gauges sets and the bottle of 404a was at about 35f. all 4 gauges were in the low to high 70sw psig. i have to remember to purge those gauges though, with the lossless fittings,, it doesnt seem to want to release the pressure as well.
    ill check it again in a couple hours
  35. #235
    Apr 2001
    79
    5,071
    35
    Measure the temperature on the side of the bottle near the bottom. This is the temp that should agree with the gauges... and lose the lossless fittings.
    At 35F, the gauge pressure should be 76 psi.
  36. #236
    Aug 2007
    racine, wi
    68
    135
    and here is the last set for today,,,
    evap air in 44f,, out 39f
    cond air in 70f,, out 87f
    suction line at bulb 37f
    pressures at 60 and 250 psig
    supheat 14f
    subcooling 11f
  37. #237
    sptyagi's Avatar
    sptyagi Guest
    hi i am sptyagi from india . i have ref system with r23 and 404 a cascade system . same problem i also faced in r23 system after repairing the fitting and recharging. at last we analysised there was some air was trapped into the system during charging. i suggest to take out complete the gas and was the system with nitrogen then vaccume it properly and charge the fress gas. hope you will get good results.
  1. Compressor loading, cooling, and range of operation.
  2. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  3. High Side Pressure is ...
    By SULTAN in forum Trouble Shooting
    Last Post: 14-08-2007, 12:53 PM
  4. Replies: 6
    Last Post: 18-11-2005, 04:30 PM
