Thread: Lennox KNHK 43E
    Nov 2007
    Peoples Republic of Geordie Land
    47
    Smile Lennox KNHK 43E
    Hi All
    Attended site to complaints of Lennox air cooled unit tripping out.
    Checked over found motor protection device stopping compressor.
    Bypassed MPD for a short period of time to find the low/high side refrigerant pressures doing hardly nothing.
    Also found paint on compressor head to be badly cracked.
    Could anyone help me with this problem.
    Oct 2004
    Scotland
    1,454
    21
    Re: Lennox KNHK 43E
    Sounds like the compressor is not starting up properly.
    Check the capacitors and starting relay.
    Then repaint the comp.
    Chillin
    and go get a cuppa
    Nov 2007
    47
    Re: Lennox KNHK 43E
    Chillin Out
    The compressor is 3 phase.
    No cappys and relays on this one.
    CoolKids
    Aug 2007
    Adelaide Australia
    70
    562
    Re: Lennox KNHK 43E
    CoolKids
    I presume this is a semi and from the info it sounds like the compressor has been getting pretty hot.
    If there is little difference between suction and discharge I would say the valves are shot and therefore not pumping and very little cold gas coming back to cool the windings causing the thermistor relay to trip.
    Pull the compressor out and replace with a new or rebuilt one.
    Paul
    Somerset
    69
    4,712
    Thumbs up Re: Lennox KNHK 43E
    CoolKids
    PaulZ is absolutely correct.
    On any recip if there is little or no difference between the suction and discharge pressures.
    Then it's a safe bet that the compressor is not compressing the refrigerant vapour. And the first thing to suspect is the valves being worn and no longer being gas tight. Also as a consequence of passing discharge valves. High head temperatures can be experianced (badly cracked paint on the head!)
    Also as Paul mentioned, semi hermetic compressors rely on the cooling effect of the suction gases. Flowing through the windings to
    cool the motor.
    Dependant on wether you or your collegues strip and rebuild these comps?
    Will determine your next move.
    Nov 2007
    47
    Re: Lennox KNHK 43E
    Grizzly& PaulZ
    Thanks for your help.
    CoolKids
  1. lennox heat pump kfhk 28 vfc
    By cool it in forum Air Conditioning
    Last Post: 23-02-2007, 07:34 PM
  2. Lennox Heat Pumps !
    Last Post: 21-12-2006, 09:39 PM
  3. Lennox fan coil unit question
    By THERMOACC in forum Fundamentals
    Last Post: 17-02-2006, 10:31 PM
  4. Lennox outdoor unit
    By frankmcbride in forum Air Conditioning
    Last Post: 16-03-2004, 07:57 PM
