    Nepal
    De superheater in Air Cooled Chiller
    Can any one please tell how doees a De superheater in air cooled chiller work? What are its advantages.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: De superheater in Air Cooled Chiller
    Desuperheater removes heat from superheated refrigerant gas after compression, but it does not remove enough heat to cause condensation of the refrigerant. The advantage is the relatively high temperature of the removed heat, the disadvantage is that the desuperheater is normally limited to 5-25% of total heat rejection.
    Aug 2005
    5,302
    As NoNickName stated the purpose of the desuperheater is to remove temperature from the gas stream.
    NoNickName, nice to see you around here. How is your work progressing?
    Nepal
    What is the advantage of de-superheating the hot gas when it would otherwise be cooled by air on the air cooled condenser any way especially when both heat is to be dissipated to the ambient air. I am assuming that the de-superheater would be in operation when the chiller is operated to cool.
    Quote Originally Posted by NoNickName View Post
    Croatia
    68
    2,261
    Hi, Rabindra
    Quote Originally Posted by Rabindra View Post
    Advantage is to use this 5-25% to heat sanitary water or something else...it is a "free" energy (already paid) and we have to see how to utilize it no need to dissipate it to the nature and then use electrical heaters or gas burners to heat something...
    Best regards, Josip
    Mar 2006
    Merate (LC) - Italy
    2,549
    The advantage is the higher temperature than condensing temperature. So, if you need to recover heat at e.g. 70°C you can't use a condenser. You need a desuperheater.
    And for US Iceman, I'm back in town. Leaving the new job for a refrigeration compressors manufacturing company. I'll be around more and more frequently.
  1. Dunham Bush Chiller Alarm
    By Regulator in forum Air Conditioning
    Last Post: 08-12-2010, 01:42 AM
  2. Trane Rtaa 213 Air Cooled Liquid Chiller
    By ahamedkyana in forum Trouble Shooting
    Last Post: 08-07-2008, 10:27 AM
  3. Water Chiller
    By lana in forum Technical Speculations
    Last Post: 23-06-2007, 01:19 AM
  4. Trane Air Cooled Chiller
    By iceman007 in forum Trouble Shooting
    Last Post: 11-04-2007, 08:30 PM
  5. Mcquay PES Flooded Water Cooled Screw Chiller
    By Brian in forum Technical Speculations
    Last Post: 05-07-2006, 09:43 PM
