Results 1 to 12 of 12
Thread: Carrier Access Codes
24-11-2007, 11:30 PM #1
Hi All.
Can anyone please help me with a problem, i am desperatly trying to get hold of the carrier service and factory level access codes for the pro dialog and pro dialog plus controls.
if you can help with this it would be very much appreciated.
hopefull thanking you in advance.
27-11-2007, 09:52 PM #2
Re: Carrier Access Codes
GSXR1340.
I am confused as to what passwords/ codes you are hopeing to get?
If you search the following link (at bottom of page)you can gain access to a large amount of pro dialog and pro dialog plus data. (in pdf format)
If necessary I may be able to help as I have some manuals on file. Could you be more specific as to what units are applicable?
http://www.commercial.carrier.com/co...MID165,00.html
27-11-2007, 10:14 PM #3
Hi Grizzly,
Thanks for the reply, I am after the service and factory access codes to enter the pro dialog and plus controllers to enable you to enter the service settings in the software etc, for example the code 11, which is in the manual for client access and will allow you on the pro dialog and the plus controller to dry test all your components of the micro board, comps, solenoids etc, but there are further codes to go in and check the machine parameters and settings ltl, lp, etc, these are not listed in the manuals for normal client access, but for service.
regards
gsxr1340
29-11-2007, 03:52 PM #4
Those codes are not listed for a reason. So that the client can not change any service / factory parameters that could possibly end in a failure. You should not need to change any of the Service or Factory tables.
01-12-2007, 08:26 PM #5
Thanks Shakey,
I know that is a very good reason, and clients should never be told even their access codes, but when you work for a manufacturing service company, its sometimes nice to go in and check these parameters when carrier havent got the contract anymore.
01-12-2007, 09:03 PM #6
hi
r u talking about 30gx
04-12-2007, 01:13 AM #7
Hi, yes the 30 gx and any of the other models 30ht etc, with the old pro dialog and the new pro dialog plus.
gsxr1340
04-12-2007, 02:13 AM #8
Hi gsxr1340
Send me an email and I can send you some info.
Paul
09-12-2007, 03:13 PM #9
Hi Paul,
can you pm me your email address.
many thanks
GSXR1340
10-12-2007, 12:15 AM #10
Hi gsxr1340
I sent you the info last week but got the undeliverable message so I sent it again looks like it didn't get through again.
When I work out how to attach a pdf here I will send via RE.
Paul
07-04-2010, 06:01 PM #11
Hi. Level 1 access code 11
Level 2 access code 88
09-04-2010, 10:10 PM #12
level 1 2222
level 2 3333
carrier fault codes
By mr saw in forum Air ConditioningReplies: 9Last Post: 30-06-2010, 03:31 PM -
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
carrier fault codes
By coolflow in forum Technical DiscussionsReplies: 6Last Post: 04-10-2009, 02:29 PM -
carrier chiller fault codes
By al in forum Air ConditioningReplies: 7Last Post: 20-07-2009, 10:10 PM -
standardisation of fault codes?
By kelvin kline in forum Air ConditioningReplies: 1Last Post: 10-10-2007, 12:30 AM
