    May 2006
    Isle of Wight, Uk
    47
    424
    osborne bottle/wine cooler
    Hello guys, today I had a look at a couple of osborne upright single door wine/bottle coolers with the condensers at low level on the front (exposed). The condenser looked fairly clean from the front but when I pulled the guts out from round the back to change the fan motor, the inner side of the condenser was chock a block with dust so the fan was blowing out towards the front through the coil. I thought these were supposed to pull through the coil from the front rather than blow through from the back, or am I being silly? I put the new motor in and it did exactly the same, looked at the other fridge and that did the same as well.
    Am I being silly or is it the way they designed the upright ones?
    Andy
    11,025
    Re: osborne bottle/wine cooler
    Not always unusual, not smart but there you go - someone thought it was a good idea.
    Nov 2007
    London
    461
    hey mate yeah it is a bit silly but makes sense really, it is designed to pull air over the compressor so you are not getting rid of the heat of compression over the compressor other wise it would overheat..
    if you look at it like that it makes sense..
    Designs are usually for a reason..
    Quote Originally Posted by Andy AC View Post
    Andy
    Jun 2005
    Stoke on Trent
    588
    Common for an Osborne.
  1. mojonnier carbo cooler common system
    By guapo in forum Industrial
    Last Post: 16-06-2011, 05:20 PM
  2. NH3 thermosiphon oil cooler
    By cygbob in forum NH3
    Last Post: 22-06-2008, 05:12 PM
  3. TXV hunting in a walkin cooler
    By dkemper in forum Trouble Shooting
    Last Post: 15-11-2007, 03:14 PM
  4. Walkin cooler
    By masooda in forum Trouble Shooting
    Last Post: 09-02-2007, 04:57 PM
  5. Thermo-syphon Oil Cooler
    By B.B. in forum Industrial
    Last Post: 31-10-2005, 01:25 PM
